04-04-2008, 05:13 PM   #11 (permalink)
retyler
Re: 65 Fairlane weird volt pulse at +wire coming from ignition.
From sitting way over here, I would suggest the starter solenoid first then maybe the starter. I could be wrong because I am sitting way over here and trying to decipher the information provided.
04-05-2008, 01:37 PM   #12 (permalink)
richiemfmead
Nope its neither. Ive had the solenoid tested and Ive hot jumped the starter. Both work fine. Thanks for the input though.
richiemfmead is offline   Reply With Quote
04-06-2008, 07:46 AM   #13 (permalink)
pops296
I know this is way too simple... but is there any chance the wires got mixed up? There normally are 2 wires that come off of the harness at the same place... water temp and coil. The water temp wire is normally a pulse wire. The coil should be constant 12 volt - switched on by ignition. I know on my '65 falcon, the harness has 3 wires with the longest going to the oil pressure sending unit. Hope this helps. And I agree with Scott... check your ground.
pops296 is offline   Reply With Quote
04-06-2008, 06:24 PM   #14 (permalink)
iwantmore
That is a good point since the dash voltage regulator pulsed the voltage to the gauges. Pops 296 is his IQ so you better listen.
68 ignition resitor wire vettemad Mustang Pages (1965-1973) 2 02-26-2008 05:50 PM
Pink resistance wire on ignition switch is burning HOT! galaxierace All Ford Techboard 10 08-30-2004 02:58 PM
429/460 ignition wire arrangement!!!! XolieX All Ford Techboard 4 12-26-2003 10:20 PM
Lime green wire coming from volt regulator? lnmrmn Galaxie Pages 1 10-16-2003 01:06 PM
Ignition Resistor Wire? Rancho Lenny All Ford Techboard 1 09-25-2002 07:26 PM
