Re: front end rebuild kits?
i looked heavily at the lm kit as well, but i found some negative anecdotal advice on the midolyne. i ended up with a polyurethane kit from mustangs plus, and so far so good. the poly kit from mp was only a touch more expensive then the lm kit (less than $50 more if i remember correctly.) everybody i asked recommended the polyurethane over rubber or midolyne. pst's polygraphite is apparently great, but almost double the price. make sure whichever kit you decide on has fully assembled upper control arms. i don't know the technical names of the parts, but the upper control arms mount to the body via a shaft on which the control arms pivot. the shaft mounts to the control arm with 2 bushings and 2 large nuts with grease fittings. apparently, the nuts are threaded into the control arms on the outside, and to the shafts on the inside as well, or something to that effect. i've heard getting the shafts mounted on the arms is ungodly difficult, and will have you ruining the threads and running to the machine shop. the mp kit was assembled, so i luckily didn't have to deal with that nightmare.
