Re: roof rail weather stripping install?
Really a pretty simple job. There's a screw which holds it in at the front of the front window, at the bottom of the A-pillar. I cant seem to remember if theres one at the lower part of the C-pillar or not. Regardless, the seal is sort of like a T, and the two short legs of the "T" lock into the stainless steel channel. I always use weatherstrip adhesive before putting the seal back in, since it likes to fall out of the channel a little bit if you don't.
Will
