07-08-2008, 07:00 AM   #1 (permalink)
rod123
idle surge
My 69 Torino has just developed an idle surge on it's 302 engine. The 650 holley is about 6 months on the rebuild. It was running great until a few days ago. I have not changed anything.
I checked all my vacuum lines today, they are ok. The car seems to run better cold and has no idle surge until warm. Being in south florida the electric choke is not hooked up or used.
I double checked the mounting bolts on carb, good and tight.
Other than pulling the fuel tank and cleaning out all the lines and replacing tank do you have any ideas?
Thanks Rod
Oh also need power window motor for the LH front and a set of power window gang switches on drivers door.
rod123 is offline   Reply With Quote
07-10-2008, 09:07 PM   #2 (permalink)
mailmandon
Re: idle surge
Mechanical fuel pump?Did you check for an intake manifold gasket leak?
mailmandon is offline   Reply With Quote
07-12-2008, 06:23 PM   #3 (permalink)
rod123
Re: idle surge
Yes mech fuel pump. I re torqued intake today no improvement.
07-12-2008, 10:54 PM   #4 (permalink)
Re: idle surge
Some surges come from carb base gasket leaks...
07-13-2008, 04:53 PM   #5 (permalink)
spiderzero
Re: idle surge
check your carb gaskets for leaks by starting the engine and spraying starter fluid around the base of the carb. if you're leaking, the vacuum will suck in the fluid and give you a surge
spiderzero is offline   Reply With Quote
idle surge rod123 Torino Pages 0 07-06-2008 02:43 PM
surge at idle cornhauler All Ford Techboard 16 03-24-2007 05:07 PM
efi surge at idle? torino501 All Ford Techboard 2 02-05-2006 01:50 PM
idle surge ujt389 All Ford Techboard 4 08-01-2005 04:40 AM
Idle surge JaxTheDJ All Ford Techboard 1 01-20-2003 10:34 PM
Probe Industries
