08-09-2009, 07:59 PM   #11 (permalink)
steeldashes
Posts: n/a
Re: Help with a T5 into a 64 Fairlane
did you ever post any pix how much clearance did it take in cowl?
08-11-2009, 05:11 AM   #12 (permalink)
Jetfixr320
I will check to see if I have any pictures, clearance is pretty tight up in there. So it was hard to get decent pictures.
I used a air hammer to "massage" the cowl. Probably 1/2" to 3/4".
Will try to post some pictures later today. Still at work in Jersey, back in Indy later today.
Jet
Jetfixr320 is offline   Reply With Quote
08-11-2009, 12:09 PM   #13 (permalink)
Jetfixr320
I think you may be able to buy a Cable from CJ Pony Parts, The clevis at Speedway Motors?
Speedway Motors also has Hyd M/C and slave Cyl setups.
I'm having trouble resizing the pictures. PM me your email and I will send some pictures.
Jet
08-18-2009, 09:41 PM   #14 (permalink)
Jetfixr320
A few pictures finally.
Jet
help-t5-into-64-fairlane-dsc00222.jpg   help-t5-into-64-fairlane-dsc00229.jpg   help-t5-into-64-fairlane-dsc00218.jpg
help-t5-into-64-fairlane-dsc00217.jpg   help-t5-into-64-fairlane-dscf9297.jpg   help-t5-into-64-fairlane-crossmember1.jpg
08-19-2009, 11:18 PM   #15 (permalink)
cartoad
Thumbs up Re: Help with a T5 into a 64 Fairlane
I also recently completed a T-5 swap on my 64. I used a cable setup utilizing mustangsteves weld-on quadrant. As mentioned this requires modifying the cowl. I cut the cowl above the clutch pedal and fabbed and installed a "tunnel" for the quadrant to travel in. this creates a "dam" in the cowl, so I installed a drain tube to prevent water from pooling. I believe that 2.75" clearance is needed from the center of the clutch pedal pivot. there is more info on the M/S site. The clutch is very smooth and way less effort is required to operate compared to the old z-bar setup. another good part of these mods are that, other than the cable under the hood you cant see any of them. As with jetfixer this was a worthwhile project and the end result fantastic. Jon
cartoad is offline   Reply With Quote
08-20-2009, 09:47 PM   #16 (permalink)
Jetfixr320
I was in the process of making a quadrent like the Mustang Steve piece, but didn't know how deep I wanted to get into cutting open the cowl.
Did you open the top of the cowl or do it all from the bottom?
Jet
08-20-2009, 11:02 PM   #17 (permalink)
cartoad
I did it all from the bottom
08-21-2009, 08:33 PM   #18 (permalink)
Jetfixr320
Cartoad, very Cool! If my car wasn't painted and wired I would have tried that. Nice job.
08-21-2009, 11:16 PM   #19 (permalink)
cartoad
Thanks jetfixer, Its not real pretty, but it dosnt leak and you cant see it. I fastened That 'tunnel' with stainless steel screws to help discourage rust. The cowl floor is very thin sheetmetal and would have been a real bugger to weld and keep from rusting. I sealed it from the top with seam sealer applied with a squeeze tube and a piece of plastic tubing. should last the life of the car.
08-22-2009, 06:04 AM   #20 (permalink)
Jetfixr320
Yeah, I had to replace half of the Cowl in my car when I was restoring it. Good times drilling all those spotwelds out. I did that in 98 I think?
How about who we are and what Fairlane we have? fairlaniac Fairlane Pages 113 11-12-2009 01:46 PM
Another new guy....67 Fairlane 500 dcs13 Fairlane Pages 8 02-01-2008 06:27 PM
My 63 fairlane sc jagscars Fairlane Pages 6 04-10-2006 11:12 PM
looking for 66-67 fairlane ford88 Fairlane Pages 1 03-21-2006 09:42 PM
Will 66 Fairlane GTA Tail Lights Fit a Fairlane 500? deernet All Ford Techboard 10 11-24-2002 02:11 PM
