08-28-2009, 01:27 PM   #21 (permalink)
8BBL427
Re: Help with a T5 into a 64 Fairlane
This has me thinking a bunch. Looks so clean and simple. I do have a few questions though.
1)What is the benefit of the quadrant over the simple clevis?
2)Why do you have to loop the cable so far forward? Is this due to minimum bend radius and conversion to a pull type clutch fork?
8BBL427 is offline   Reply With Quote
08-28-2009, 11:55 PM   #22 (permalink)
cartoad
The benefit of using the quadrant is that you can use a stock mustang cable(available about anywhere) without any modifications, such as threading the pedal end. I chose this method because the math was already done as to length of travel ect. I have nothing against the clevis setup, I simply chose the quadrant.
As for the long sweeping loop of the cable, Its what you get with a stock mustang cable. Its length actually comes in handy to route around barriers such as headers and exhaust, motor mounts ect. I am sure a shorter cable may be used and routed about anyway that would work.
I hope others chime in, these are just my simple minded thoughts.
cartoad is offline   Reply With Quote
10-25-2009, 08:19 PM   #23 (permalink)
joegresham
Originally Posted by Jetfixr320 View Post
Wanting to swap my c4 to a t5. Has anyone done the swap?
If so did you modify the crossmember or buy one? If bought, from who?
Cable or mechanical or hydraulic clutch actuation?
I've contacted DarkHorse Performance several times. Says he can help but never gets back in touch so I can get parts fro,m him.
Thanks for any help.
Running a 289 with hooker 6134's also.
yes i have successfully installed tremec 5 speed with hayes cable cluth assembly, bought a clutch,brake pedal assembly out of a 63 fairlane for 25.00, bought a T-5 alum bellhousing, with clutch fork, for 100.00 junkyard price, crossmember out of mustang, C-4 transmission mount, will install on tremec to fit crossmember, i took a ford latemodel flywheel 50 oz to machine shop for 50.00 they machined it to a 24 oz for my 68 302, internal balance engine, installed a 1980 mustang clutch disc and pressure plate made by zoom, use pro 5 shifter works great, with ford 8" locker rear end 3.73 gear
joegresham is offline   Reply With Quote
How about who we are and what Fairlane we have? fairlaniac Fairlane Pages 113 11-12-2009 01:46 PM
Another new guy....67 Fairlane 500 dcs13 Fairlane Pages 8 02-01-2008 06:27 PM
My 63 fairlane sc jagscars Fairlane Pages 6 04-10-2006 11:12 PM
looking for 66-67 fairlane ford88 Fairlane Pages 1 03-21-2006 09:42 PM
Will 66 Fairlane GTA Tail Lights Fit a Fairlane 500? deernet All Ford Techboard 10 11-24-2002 02:11 PM
