08-21-2008, 02:08 PM   #1 (permalink)
pat2345
Tire help
Hey guys,
Here is the question of the day for you, I'm building a drag car out of my 64 post car and need help with tire fitment. The class I want to run will allow me 10 inch slicks but I can't change the wheel houses, so no mini tubs or any other alterations. I can change the rearend width to whatever I need and I can also roll the wheel lips. Now the question is can I fit a 10 inch slick under the cars stock wheel houses? I've measured quite a few times and it appears that I can but has anyone tried it and if so what combination are you running. My goal is to fit 28x10 slicks under it so lets hear what any of you have tried. Thanks for the help.
pat2345 is offline   Reply With Quote
08-23-2008, 06:55 PM   #2 (permalink)
351bolt
Re: Tire help
I have 275/60/15 Nitto drag radials on mine. THey are 28" tall about 9" wide. They are on 15x8 Weld Draglites with 5.5" backspace. I have 9" out of '59. That rear end is like 3/4 to 1" wider than the stock 8"
I also have ladder bar rear suspension under mine. The rear end has also been moved back about 2 inches. I had to trim the outer wheel lip and "massage" the inner lip, just slightly.
If you don't move the rear end back I don't think you can run a 28" tall tire. IT will hit the front of the wheel well.
Pete
64 Fairlane under construction, 420W, C4, ladder bars, etc
92 Mustang LX Coupe 4cyl power
351bolt is offline   Reply With Quote
09-03-2008, 11:16 AM   #3 (permalink)
Scarelane
Re: Tire help
read this. . . .it is what i did and worked well. talks in detail about tires on page 3 i think . .
http://www.fordmuscle.com/forums/fai...st-bucket.html
1962 Galaxie, 223, 3 on the tree
1964 Fairlane, BBF, C6, A/FX Clone
1967 Cyclone GT, 390, Toploader
1970 F100, SWB, 428, C6 (retired daily driver)
Scarelane is offline   Reply With Quote
Debate with my supervisor(25" tire vs 26" tire) Spali32 All Ford Techboard 9 04-18-2008 08:53 PM
what is the tire diameter. 17x8 wheel with 245/45 tire? RPM All Ford Techboard 5 12-14-2006 09:28 PM
drag racing - small front tire vs. big front tire? 63SportsCoupe All Ford Techboard 2 06-01-2004 12:15 AM
I need tire help too. gchero351 All Ford Techboard 2 05-28-2004 12:38 PM
Biggest, Widest Tire for 65\' Galaxie...Best Hookup Tire? 65Galaxie500 Galaxie Pages 13 04-21-2004 03:15 AM
