Re: Vintage Venom Disc Brakes
The calipers are different between the cobra and the regular mustang. It is the caliper itself that has the different offset built into it that allows for the use of the big rotors or the small ones. The calipers that I am using for the swap on my Dad's car are for the 11" brakes. If I were using cobra calipers on the 11" rotors, they would "bolt on" even closer to the center of the rotor on the adapter bracket, because of the longer reach. So in short your friend unbolted his stock brakes and put the big rotors on and bolted the cobra calipers on without having to modify anything. Here is a picture comparing the two styles of calipers. Notice how far down the mounting holes are on the cobra's
Steve 64 Fairlane S/C 289 lentech AOD 8.8 strut front suspension
