07-07-2009, 07:29 AM   #11 (permalink)
Scott66GTA
Re: motor tap !
your warm pressure is good, the cold is kinda high... Are you running a high volume pump? From what has been discussed on the FordFE forum, for a flat tappet engine, 1200 ppm if zinc is minimum... check out you favorite oil for info.... The high mileage oils usually have this... There as an additive you can buy too, which would go good w/ the synthetic...
Scott66GTA is offline   Reply With Quote
07-08-2009, 01:57 AM   #12 (permalink)
super-fairlane
Re: motor tap !
What is the additive called?
68 ford fairlane:
351C.
super-fairlane is offline   Reply With Quote
07-08-2009, 04:12 PM   #13 (permalink)
Scott66GTA
Re: motor tap !
you had to ask.... um.. there's GM EOS supplement, avail at GM dealers,
summit racing has:
GM Performance 12345501 - GM Performance
Trick Flow Specialties TFS-94000
07-08-2009, 07:40 PM   #14 (permalink)
super-fairlane
Re: motor tap !
Thanks Ill look in to that oil supliment.I forgot to write about the oil pump and its pressure. When I hooked up the gages I was suprised about the oil pressure it seemed high to me. I expected 50 psi. cold and about 30 psi hot may be its a high valume pump or the previose owner took the safety valve of a stock volume oil pump.
68 ford fairlane:
351C.
07-09-2009, 08:02 AM   #15 (permalink)
Scott66GTA
Re: motor tap !
the thick oil will raise the pressure like that when it is cold... I've seen higher preeure, high enough to blow the filter apart...
07-09-2009, 11:33 PM   #16 (permalink)
super-fairlane
Re: motor tap !
How high of a pressure did you see to blow the oil filter apart?
Today I got the carb back on and I let it run for about 2 hours while I tuned the carb. With 1 quart of MMO and 3 1/2 of the 20-50 valvoline vr1 the motor started up nice and quiet with no valve train noise. With the MMO it started with a little less oil pressure, it srarted at 68 psi. cold and 38 hot at idle, and when I put it in drive with the brake on it had 30 psi. How does that sound to you?
PS. I researched the level of Zink (ZDDP) in the vr1 and it has 1200 ppm. witch is good for these motors, I just wish they had more of a selection of wieghts on the shelf. Next oil change Im going to look into the synthetics like you were saying.
68 ford fairlane:
351C.
Motor is in! shumakerscott All Ford Techboard 8 12-17-2007 01:26 AM
HO motor with fuel pump on the timing cover, so whick motor??? Ronbuell Mustang Pages (1979-1995) 8 05-08-2007 09:03 PM
390 motor Malik2 Galaxie Pages 14 11-17-2006 02:54 PM
What motor is this? TheGmKiller331 All Ford Techboard 9 07-31-2004 01:05 AM
Some pic of my motor windsoreight All Ford Techboard 5 09-14-2003 09:53 PM
