01-01-2002, 03:50 PM   #21 (permalink)
coolfalcon
The Falcon Pages! Ford Falcon talk or questions?
Just bring it in to the new year.
Happy new year everyone.
01-01-2002, 05:48 PM   #22 (permalink)
89 coupe
89 coupe is offline   Reply With Quote
01-01-2002, 05:49 PM   #23 (permalink)
89 coupe
Happy new year!
01-21-2002, 07:22 PM   #24 (permalink)
radracing
I think we are going to buy a 64 falcon chassi car and it has a title to it. we can have some fun with it and also make it streetable too!
Alan
radracing is offline   Reply With Quote
01-25-2002, 09:52 PM   #25 (permalink)
coolfalcon
Hey 89coupe I bought a set of inserts for my w block to put a cleveland crank in it. what do you think of them also have 4 bolt caps with new bolts too the out board bolt is a 3/8. [img]/phpBB/images/smiles/icon_smile.gif[/img]
01-26-2002, 05:12 AM   #26 (permalink)
89 coupe
I don't think the 4 bolt mains are necessary for any 351W block unless you'll be twisting it over 8000RPM or making over 850-900 horse but you would have a different setup that I haven't seen in a while. A 2 bolt main block and main guirdle will hold solidly to and a little above 750HP safely and reliably and with a partial 25%-40% fill in the block with Block Fill will up that number to 850-900HP easily but above that a 4 bolt main will be needed to keep the caps from walking all over the place. The smaller journal of the 351C isn't a critical factor in a non-endurance road race or non-asphault roundyround races like quarter mile drag racing and dirt roundy round racing where you don't have to run more tham 50 or 100 laps at which point a looser main bearing clearance and high volume and high pressure pump would flow enough oil past the main bearings and rod journals to keep them cool for moderate endurance races. The 351C 4 bolt mains in the Windsor would give you extra piece of mind and a more uniqueness to an already unique and attention getting Falcon. It adds more flash to the description of your car... "yeh, it's got a 4 bolt main 351W with a 351C crank and ...." and has a neatness factor or "cool" factor that I like since it isn't done much anymore. In all honesty, the stock 351W block with good main studs and main guirdle will handle more than you'll be willing to throw at it since it is a street car and has to have some street manners and I don't think you can tolerate as radical a setup as I can on the street so the 2 bolt 351W block would be fine. What engine are you building for the Falcon and what kind of go fast goodies do you plan on putting in it? Sounds interresting so far.....
01-26-2002, 10:45 AM   #27 (permalink)
coolfalcon
I've allways wanted to do this conversion. I wanted to make a bullet proof engine male capable of spinning 8000 g's plus and then set it up to run 7500 all day. I'ts been one of my visions. Also i just came across the conversion parts real cheap with allmost enough part to do two motors everything execpt one rear main cap for a 100 bucks. One other thing is i can do all the machine work myself except for the line honing and the deck squaring. Engine parts as follows a 4340 crank 3.85 stroke 6.2 carrillo rod .927 2.1 weisco pistons have to taylor them sticking out of the hole .02 vc jr heads supervc intake .720 lift roller cam. I'm not going to drive this every day of corse. I just want to have one realy fast car in my life. While i put all the pieces togethere I may just drive the car around this year with a fairly stock 351w i miss driving it and having people looking at it.
01-27-2002, 10:56 PM   #28 (permalink)
89 coupe
Sounds like a plan!
01-30-2002, 12:55 PM   #29 (permalink)
coolfalcon
Hey Dyno Tom or 89 coupe would one of you guys go to my web site and tell me what you think no holds barred tell me if it takes to long to load if i should shrink the pictures change layout anything will help.
Thanks Bill
01-31-2002, 12:56 AM   #30 (permalink)
DynoTom
I think the site looks nice Coolfalcon![img]/phpBB/images/smiles/icon_biggrin.gif[/img]
I wish I had more pics of my Falcon going through the steps to make it,I only have a few and they are pretty far between steps?
Oh well, Im taking more from here out.
