02-19-2003, 04:17 AM   #1 (permalink)
19falcon66
looking at tubing my 65
hey I was wondering if you guys have any ideas on tubing my 65 when i get it and how short do you think i should have to cut my 9 inch rearend housing to get 12 0r 13 inches uf rubber under the car and what u guys used to relocat the leaf springs. anything will help.
19falcon66 is offline   Reply With Quote
02-19-2003, 11:40 AM   #2 (permalink)
dwood
I posted a message on your other question. If you are going to tub your car, the size of the rearend will not matter. YOu could get one out of anything as it will need to be cut anyhow. Get one out of a 70's truck or van.
dwood is offline   Reply With Quote
02-19-2003, 04:36 PM   #3 (permalink)
NMustang
If you move in the leaf springs in about four inches on each side. you can fit a 10inch wheel in there no problem (this is without rolling the fenders too). Crites restoration has a kit to relocate the springs. I have a 64 falcon with 17x10 wheels in the rear. This helps out as you can fit a wider tire without actually cutting into the car. Unless you want to, then tub away.
NMustang is offline   Reply With Quote
02-19-2003, 08:40 PM   #4 (permalink)
coolfalcon
31x18x15 on mine. Why leave the leafs in there go with a ladder bar coil over. Allot nicer less weight. Buy the tires and wheel you want to put in there first. Then start the project.
02-19-2003, 09:57 PM   #5 (permalink)
ckelly
Buy the wheels and tires first. Remove the rear and springs, cut the inner fender wells as needed to fit the tires like you want. Measure between the inner mounting flanges of the wheels. That will be the flange-to-flange distance you need. My suggestion is to take this dimension to a rear end shop and have them make a housing and order axles to accomodate your need.
Alternately, as suggested, get a rear that fits, then get rims to place the tires where needed and move everything in the way.
02-19-2003, 11:35 PM   #6 (permalink)
futura 64
If you are serious about back halffing the car, keep in mind this is not a job for the sqeamish,or the inexperienced. You need good welding skills and good fabrication skills and a tape measure! Measure, measure and measure again! A great resource is the Chris Alston chassis catalog...the latest issue just arrived over the weekend. They back half a 65 Mustang coupe with a 4 link and have all the photos and details. I did mine in 1985 and went with a ladder bar setup with coil- over shock set up. Currie handled the narrowing chores on my 9 inch and resplined the axle shafts.Been fine tuning ever since, and am finally happy with the results.
Keep in mind though, when you're done, a car with huge wide tires on the rear and tall skinnies on the front will handle like a cow on skates on the street. If the streets get wet...well it's like a cow on skates ON CRACK! [img]/phpBB/images/smiles/icon_lol.gif[/img]
futura 64 is offline   Reply With Quote
02-20-2003, 02:47 AM   #7 (permalink)
19falcon66
where did you get ur lader bar set up i would like to try that since yea it will be lighter and what kind of gears and posi unit should i go with i want to do 4.11 gears in the rearend. and i think i will buy the tired and rims and then go from their i hear that alot. thanks...
02-20-2003, 02:50 AM   #8 (permalink)
DynoTom
www.artmorrison.com is the place my ladder bars came from.
02-20-2003, 06:28 PM   #9 (permalink)
coolfalcon
Its not as hard as it seems. You do have to be able to run a good bead when welding use a square and measure very close. I did mine with no prior experience and it goes straight down the road hooks good looks good. Saved a lot of money
02-21-2003, 03:29 AM   #10 (permalink)
19falcon66
hey what kind of tires are you running to get 31x18x15 and what size are your tires up front just so i can get an idea of what i am going for and what rims did u end up using i wa thinking about the weld draglights on my car. thanks.
