11-05-2004, 09:48 PM   #1 (permalink)
rustedduster
got a question...
... regaurding front springs. since the age of 18 (now 26), ive been tinkering with all my friends fox body 5.0s and we usualy used 4 cylinder springs up front for drag racing. would the same idea (using 6 cyl. springs) work for my sbf powered comet? all replies, ideas, and/or product info welcome. thanks all.
rustedduster is offline   Reply With Quote
11-07-2004, 11:01 PM   #2 (permalink)
coolfalcon
got a question...
When the 6 er's were ;eft in my 60 with the v8 they rode with only about an inch and a half travel tell it bottomed out. Not good.
11-08-2004, 01:17 PM   #3 (permalink)
got a question...
Sometimes... There is no diffrence between 4 and 6 cyl springs except the part #...
11-08-2004, 04:24 PM   #4 (permalink)
ckelly
got a question...
The later model 6 cylinder and some of the V8 springs are the same. Probablyneed to figure a rate, then look for a spring. Moroso has some Tricks that may work. The ones I run with the 351C have the same rating as the stock 289 springs. And they do not let the front down at all. Right at about normal ride height.
11-08-2004, 07:08 PM   #5 (permalink)
P64falcon
got a question...
I think that the springs for 64/65 falcons and comets are the same.
When I converted my U code 6 cyl. falcon to a 302 the ride height did not change. after putting on aluminum heads and intake and a fglass hood the front end is about 1 1/2" higher (took off well over 100lbs.) and the car has a bit of reverse rake to it. I plan on cutting 1/2 a coil to drop it back down.
The same should apply to the comet. If it is a 6cyl car leave in the springs and see how it looks/ride with the V8. you can always get another set if you have to.
Just fyi, I have heard that the mustang 1" drop springs won't lower a falcon the same way they do the mustangs probably the same for the comet if you thought of going that route.
P64falcon is offline   Reply With Quote
11-09-2004, 09:21 PM   #6 (permalink)
F15Falcon
got a question...
Hey P64, you sure do talk about that car alot, but you never take it to the track, what are you afraid of, come on lets race!! I guess I'll have to race you with this:
11-10-2004, 05:02 PM   #7 (permalink)
P64falcon
got a question...
Let's go brother. TA is closed for the season, no 60 foot times or mph. DD has the clocks running on fridays though.
I have no idea exactly how fast this thing is going to go since I got it back on the road. 3 weeks ago I took out The RBH racing camaro, and somebody's firechicken, before i lost to bottle bills cobra. Only one car length and he's running a 150 shot.
