07-28-2005, 01:52 AM   #1 (permalink)
65FordForever
62 falcon brakes
i want to replace the hardware in the all the drum brakes on my sedan. i have the tires off, but am stuck. how do i get the drum off? i was tempted to jus start unbolting everything on the back of it, but common sense caught up with me. how do i get these off?
65FordForever is offline   Reply With Quote
07-28-2005, 10:55 AM   #2 (permalink)
Mr.Ed
62 falcon brakes
I am going to presume you have adjusted the brakes in to make the drum loose enough to come off. If you have done that and they are still stuck because they were rusted to the drum, you can try hitting the drum carefully to break the shoes loose. Tried that too, huh? Now you have to unblot everything but there is no guarantee that will work either. I had the same situation on a set of front spindles but the advantage was that they were off of the car.
Good luck!
Mr. Ed [img]/phpBB/images/smiles/icon_frown.gif[/img]
Mr.Ed is offline   Reply With Quote
07-28-2005, 03:51 PM   #3 (permalink)
65FordForever
62 falcon brakes
how do u adjust the brakes in? the drum is able to turn, if thats loose enough. i'm sick today, maybe i'll give it a go later. thanks for the advice
