12-16-2005, 05:50 AM   #1 (permalink)
FlyByFord
Driveshaft Length
I have swapped in a C4 in place of the 2-speed...
I understand that the driveshaft will need to be shortened. Does anyone happen to know how much it will need to be shortened?
(I have heard "about" an inch)
Specs:
260, C4, and stock 8" rear end.
FlyByFord is offline   Reply With Quote
12-16-2005, 10:20 AM   #2 (permalink)
Iethiopian
Driveshaft Length
Stick the spline yoke into the back of the tranny, then slide it out till you have 1 to 1 1/4" sticking out past the rubber boot/seal on the trans, then get a measurement from the center of the eye on the spline yoke to the center eye of the yoke on the differential. This should be your length. [img]/phpBB/images/smiles/icon_tup.gif[/img]
This is becoming one empty nest.
Ras Daniel [img]/phpBB/images/smiles/icon_cool.gif[/img]
Iethiopian is offline   Reply With Quote
12-16-2005, 03:16 PM   #3 (permalink)
1bad6t
Driveshaft Length
Ras is correct. I would hate to take someone word and lay down the $$'s and find out it is too long or keeps falling out of the transmission
12-18-2005, 05:48 PM   #4 (permalink)
Falconinpa
Driveshaft Length
Yes Ras is right. That measurement is known as centerline to centerline, and take it to a driveline shop. They have the correct equipment to press it together, weld it, and balance it in a balancer specifically made for driveshafts. Years ago there were machine shops that said they could do it, but it wasn't the right way. I used to work in a driveline shop building/ modifying driveshafts and I saw alot of ugly and scary work.
Falconinpa is offline   Reply With Quote
12-20-2005, 07:01 AM   #5 (permalink)
Riley
Driveshaft Length
When you take your measurements have the car's weight on the rear springs. As the rear end goes up and down the mearsurement changes. I put the transmission yoke all the way in, measure and then subtract the proper amount for play. Same result as Ras.
<font size=-1>[ This Message was edited by: Riley on 12/20/05 10:03pm ]</font>
Riley is offline   Reply With Quote
