09-23-2007, 04:00 PM   #11 (permalink)
gbic1
Re: Old Faithful??
For what it is worth I have never seen a water pump cause a overheating problem with out seeing something major wrong with it when I pulled it off. ie Ford contour where impeller cracks and spins on shaft or some Taurus and Tempos where the coolant was so bad it rusted off the impellers. I have seen lots of thermostats in backward or bent. Also saw a lot in the housing crooked on 289 and 302.
09-23-2007, 04:34 PM   #12 (permalink)
Stroker83
Re: Old Faithful??
2nd pump... I put the new pump on and left the T-stat out.... I am guessing it was a bad pump... I put the stock pump on it (the part number it called for) I never changed timing covers if thats what you were meaning... I won't know if the T-stat was the problem untill I put it back in... But since it's working now, I don't see a reason to mess with it...
Stroker83 is offline   Reply With Quote
09-23-2007, 05:10 PM   #13 (permalink)
gbic1
Re: Old Faithful??
Did you see a loose impeller or blocked ports from too much sealer?
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
09-23-2007, 08:04 PM   #14 (permalink)
Stroker83
Re: Old Faithful??
Nope sure didn't.... I am starting to think the impeller on the "old" New water pump was pressed on backwards. It was a reman and not a new pump.... without seeing the other pumps impeller, I can't be sure...
09-24-2007, 05:28 PM   #15 (permalink)
retyler
Re: Old Faithful??
If you have the new/old pump just examine the rotation of the impeller. You should be able to tell. The pump turns clockwise.
