09-23-2007, 09:13 PM   #1 (permalink)
jteunis
How to remove trim from sides?
I just bought a 64 Falcon and want to pull the trim that runs along the side and entire length of the car. How do you go about removing the trim without damaging or bending it?
thanks,
Johnny
jteunis is offline   Reply With Quote
09-23-2007, 10:59 PM   #2 (permalink)
Re: How to remove trim from sides?
Very carefully.....
There is a bolted clip on each end with rivoted clips in between I think....
There's a way to lift it up adn pry it out and away from the clip spring then tild the other way and down to rock it off the clip.
I hope I said that right...
Just experiment and be carefull.
FE
Honor!
09-24-2007, 05:24 PM   #3 (permalink)
retyler
Like FE noted, the trim is bolted on at the ends of each piece. You have to remove the door panels and rear inside panel. There are some in the trunk also. I used a small flat steel bar ,aka, as paint scraper and was able to pop it off the clips. I found that a putty knife was to flimsy. Once you get the hang of it, it is a pretty simple operation.
09-24-2007, 09:01 PM   #4 (permalink)
jteunis
When you both say "bolted" at the ends and just to make sure I have it right. If I look behind the door panel, fender or inside trunk, I'll actually see a bolt or nut that's holding the trim on at the ends? And any points in between the bolts, is mounted using some type of clip that I can pry off?
I just want to make sure I have it right before I get started. The trim is in really good condition, but I want to remove it before I start doing the body work and don't want to ruin it by doing things the wrong way.
thanks,
Johnny
09-24-2007, 09:32 PM   #5 (permalink)
1bad6t
Here is a digram on how the front trim is attached http://1bad6t.com/diagrams/64FrontTrim.jpg
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
09-25-2007, 12:29 AM   #6 (permalink)
Yes, there will be a 3/8" or a 7/16" nut on the end clip. the rest should pop off if touched just right...
Honor!
09-25-2007, 08:38 PM   #7 (permalink)
jteunis
Cool thanks for the tips and the diagrams too! All very helpful.
thanks,
Johnny
switching sides for alternator slyman2087 All Ford Techboard 8 07-10-2005 05:10 PM
How do I remove the chrome trim around glass? mels65 All Ford Techboard 5 06-23-2005 03:47 PM
Brakes pull to sides at highway speeds... Help? adgdghr123 All Ford Techboard 9 02-02-2005 01:33 PM
how do I remove trim around windshield Pale Rider All Ford Techboard 3 06-23-2003 12:57 PM
How do I remove anodizing from aluminum trim mreifers All Ford Techboard 10 11-02-2002 10:45 AM
