09-29-2007, 06:36 PM   #1 (permalink)
x00shocker00x
Question leaf sping help!!!!
I am moving my leaf springs in board. i need help with strut location. I am not sure if i can just mount the struts straight up and down or should the be a some sort of a angle. Please help
x00shocker00x is offline   Reply With Quote
10-01-2007, 02:07 PM   #2 (permalink)
P64falcon
Re: leaf sping help!!!!
When I did mine I used the crites kit, lots of space now with the poor mans minitub.
Take the lower shock mount plates and swap the left to the right and the right to the left then flip them over. It gives an angle to the shock and runs it over the leaf spring. At first I thought it wouldn't work but it did fine. May need to trim back the area that mounts to leafspring so it will be flush like when the plates are right side up.
Bad little Bird
P64falcon is offline   Reply With Quote
ford mono leaf leaf springs 347LX All Ford Techboard 1 09-06-2007 02:26 PM
add a leaf rod123 Galaxie Pages 2 04-11-2007 12:47 AM
coil sping insulator 8675309 All Ford Techboard 3 05-19-2005 07:28 PM
5 leaf or 5 1/2? slyman2087 All Ford Techboard 4 03-25-2005 07:07 PM
Leaf Springs - 4, 41/2 or 5 LEAF, HELP....... Nitmare67 All Ford Techboard 2 04-25-2003 03:33 PM
