09-30-2007, 02:55 PM   #1 (permalink)
P64falcon
Rear Disc Brakes from what?
Hey guys looking into rear disc brake options for my '64 Falcon. Currently has a small bearing 9 inch that is narrowed 2" compared to the stock 8".
Surfing the web has revealed several very expensive aftermarket kits but I'm a bit of a more time than money guy so junk yard swaps are usually easier for me. Looking on e-bay (I know) there are several similar small bearing kits (Used) salvaged from some other vehicles.
eBay Motors: 65-73 Mustang rear disc brake conversion (item 200157914075 end time Oct-06-07 21:40:28 PDT)
or
eBay Motors: 65 66 67 68 69 70 71 Mustang Rear Disc Brake Kit Falcon (item 280156510873 end time Oct-02-07 18:30:00 PDT)
Any Idea what vehicles these are harvested from and what Modifications are needed to the axle flanges to make them work? any other options?
Side note; I already have a GeoMetro power brake set-up for the car and granada front disc's installed.
Any info is always appreciated.
Russ.....
Bad little Bird
P64falcon is offline   Reply With Quote
09-30-2007, 04:51 PM   #2 (permalink)
1bad6t
Re: Rear Disc Brakes from what?
91-95 Town Car, Crown Vic, or Grand Marquis
[CM] Re: 1966 Mustang GT350 rear drum brake upgrade
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
09-30-2007, 07:44 PM   #3 (permalink)
P64falcon
thanks for the link, Very good write up on the swap.
Bad little Bird
10-01-2007, 06:44 AM   #4 (permalink)
tachrev351w
Scarebird Classic Brakes has a small bearing 8/9 inch bracket for around $100. I order there bracket for the front disk brakes. Very well made piece, I thought.
They send you the bracket, and a parts list of stuff you can get from a local parts store new. The front disk setup I have uses GM calipers and 2WD ranger rotors. I priced the entire front disk conversion on my Falcon, including the price of the brackets, at ~$360. I thought that was pretty good.
Just something else to look into and consider. Scarebird has some stuff on ebay as well.
1968 Ford Falcon 393W C4 conversion in progress
All-Motor 10's, here we come.
1997 Chevy C1500 TREEfiddy
http://ntrracing.dyndns.org
tachrev351w is offline   Reply With Quote
10-01-2007, 08:02 AM   #5 (permalink)
gotyurback
I used the scarebird setup on my Comet rear. It's a pretty good setup. The brackets were 105.00 and it come with instructions and a list of parts necessary to complete the installation, I installed the whole thing for less than $250.00. You have to do a little modifiing to get the rotors to clear the axle flange. You can use an angle grinder to knock off about a 1/4" of metal off the axle flange, I just paid the machine shop $20.00 to lathe the 1/4" off both axles, it was much cleaner look. Everthing else just bolted into place. They stop very good.
$105.00 brackets from Scarebird
$51.00 Chevy Lumina rotors
$20.00 Two used Eldorado calipers they have E-Brake setup on them
$18.00 Two caliper rebuild kits- Oriell auto
$21.00 Two Caprice brake hose
$20.00 Machine shop service
$235.00 Total
1969 Ranchero 500 351W
1963 1/2 Galaxie 500 XL 390FE
1964 Comet Caliente 347 EFI
1967 Mustang 289
1954 2dr Customline
gotyurback is offline   Reply With Quote
8" rear with disc brakes lees6t Falcon Pages 12 01-18-2008 05:22 PM
Explorer rear disc brakes on 8\' rear lees6t All Ford Techboard 3 03-23-2005 08:13 AM
Rear disc brakes on a 65 galaxie junkyardjeff Galaxie Pages 7 10-24-2004 11:56 AM
Lincoln rear disc brakes on 8\" rear end fordracerguy All Ford Techboard 4 09-08-2003 10:43 PM
HELP NEED 9" Rear end with Disc Brakes machI1973 All Ford Techboard 3 10-20-2002 11:18 PM
