12-19-2007, 11:27 AM   #1 (permalink)
JDKRUZER1
8.8 Rear
I Found The Correct 8.8 Rear End Out Of A 64 Four Speed Falcon With The Tapered Tubes With Spring Plates And U Bolts, Looks Good And Is Complete Ecept Foe Drums.i Will Replace Wheelcylenders ,shoes And All Hardware . I Think It Is A Posi,the Guy Said It Would Spin Both Tires. Sould I Replace The Axel Bearing? It Makes No Noise When I Spin The Axel Hub And Thereis No Loose Play Anywhere. So I Don"t Know.
JDKRUZER1 is offline   Reply With Quote
12-19-2007, 12:59 PM   #2 (permalink)
Just Jim
Re: 8.8 Rear
The '64 Falcon V8 had a 8 inch not 8.8. If both axles spin the same direction when one is turned then it probably has a posi. If the one axle is turned and the other one goes in the opposite direction then it is an open rear which I bet it is. Sure wouldn't hurt to replace the axle bearings and seals.
\'58 Morris Minor 289 S/S MM
12-20-2007, 07:29 AM   #3 (permalink)
Mr.Ed
Re: 8.8 Rear
Especially while it is out of the car.
Later!
Mr. Ed
1971 Torino 500 hardtop, 302, Cruise-O-Matic.
Mr.Ed is offline   Reply With Quote
12-21-2007, 08:08 AM   #4 (permalink)
retyler
Re: 8.8 Rear
I would also replace the pinion seal, especially if it has been sitting for awhile.
12-21-2007, 08:17 AM   #5 (permalink)
Mikes66
Re: 8.8 Rear
Drain it, and check the fliud for any metal, by using a strainer. It would not hurt to open the pumpkin, and change that gasket while your at it. This will also let you get a good look at the gears, and see if there is any wear damage.
You can chek the ratio, by simply turning the axle 1 complete trun at the wheel side, and counting how many revolutions the input yoke will make.
[SIGPIC][/SIGPIC]
SSBC rear disc conversion for 65-66 Mustang 8\" rear ga289stocker All Ford Techboard 10 11-08-2005 07:40 AM
Crown Vic rear discs for 8 inch rear Just Jim All Ford Techboard 4 06-20-2005 03:59 PM
Why A Price Difference Between R.Rear And L.Rear Brake Roters 77ltd All Ford Techboard 4 08-23-2004 01:08 PM
8.8 cougar rear into fox stang w/ t-bird TC rear disc conv. or 5 lug conv. with rear disc Foxbodystang All Ford Techboard 1 11-30-2003 09:36 PM
Lincoln rear disc brakes on 8\" rear end fordracerguy All Ford Techboard 4 09-08-2003 10:43 PM
