12-26-2007, 09:21 PM   #1 (permalink)
mc
AOD for 60's 170/200
I know I've seen adapters adapting a 4/6cyl 5 speed to the 170/200's. But has anyone ever adapted an automatic overdrive to the early 170/200's? Any info or advice on were to start? Thanks, Chris
62 Comet wgn-289/AOD/Pdisc
64 Vespa-186cc big bore cyl/expansion chamber/24mm carb/stroker crank/upgear kit/elect ign-- 13-15HP(stock 5hp)!!!
mc is offline   Reply With Quote
12-31-2007, 05:02 AM   #2 (permalink)
plworking
Re: AOD for 60's 170/200
I am looking for articles about adapting the 4/6 cyl 170/200 to a 5 speed. Could you help me locate what you have seen?
plworking@juno.com
plworking is offline   Reply With Quote
01-01-2008, 12:55 PM   #3 (permalink)
rayell
I would also like to know. I have never seen anything but 177,303, and Dagenham 4spds, behind those engines,
Ray
[img]http://www.fordmuscle.com/pics/rayell_rayell_sig.jpg[/img]
rayell is offline   Reply With Quote
01-02-2008, 12:46 AM   #4 (permalink)
mc
You guys should check out fordsixperformace.com
people just about the inline ford sixes; tons of great info!
01-02-2008, 09:38 AM   #5 (permalink)
Washernozzle
I saw a post on Fordsix.com where someone drilled the V8 AOD bellhousing for the top bolt holes, and then used a 300 I-6 flywheel to bolt the torque converter to. Other than that theres no other way to do it that I know of. The bellhousing bolt pattern on the 6 cyl blocks is different from the ones the V8's have. They made a few 200 blocks with the V8 bellhousing pattern, but they are hard to find.
Washernozzle is offline   Reply With Quote
AOD for 60's 170/200 mc All Ford Techboard 1 12-27-2007 05:57 AM
rods of 50's and 60's Ranchero65 The Garage 1 08-30-2007 05:30 PM
How flexible was Ford production process in 60's? 69XL All Ford Techboard 2 07-11-2003 03:22 PM
More 60's Hot Wheels for your viewing pleasure.. desertdroog The Garage 4 02-05-2002 11:27 PM
Will McCreary L-60's fit on a 1990 Mustang? Joe In Mtown All Ford Techboard 1 02-02-2002 12:22 AM
