01-03-2008, 06:17 AM   #1 (permalink)
JDKRUZER1
Lay That Grinder Down Boy!
Thanks For All The Advice. I Will Not Use The Wire Cup To Remove That Paint.i Guess When I Am Ready I Will Buy Or Rent Some Kind Of Media Blaster, But I Have Been Told You Can Warp Panels That Way Too. Either Way It's Gona Be Tough Work But I Have To Get Under There And See What I Have . I Know It Will Be Worth It. Thanks Again All You Guys . Jd
JDKRUZER1 is offline   Reply With Quote
01-03-2008, 06:27 AM   #2 (permalink)
Mr.Ed
Re: Lay That Grinder Down Boy!
Good luck in your choice.
Later!
Mr. Ed
1971 Torino 500 hardtop, 302, Cruise-O-Matic.
Mr.Ed is offline   Reply With Quote
01-03-2008, 09:07 AM   #3 (permalink)
Good Luck JD, and don't forget to keep us informed! and Updated with Pictures!
That Air craft stripper is really really easy to use, and it's neutralised with water so there's very little environmental impact.
Clean up is as easy as letting it dry for a day on the floor then sweeping and scraping it up and tossing it out with the sanding dust.
FE
Die Grinder Cutters/Bits ?? tdf_46 Home Porting Cylinder Heads 19 04-10-2008 11:33 AM
8,000 rpm grinder... Help... imported_RoadRunna Home Porting Cylinder Heads 8 09-04-2007 02:03 AM
