02-19-2008, 08:04 AM   #1 (permalink)
falcon1
Headers for Victor Jr Heads port match
Anyone know of headers that fit the 1 1/2 x 1 1/2 exhaust port size of a victor jr head and fit correctly on 65 falcon?
falcon1 is offline   Reply With Quote
03-10-2008, 07:52 PM   #2 (permalink)
Kenny64
Re: Headers for Victor Jr Heads port match
Did you get any info on this? I'm looking in to the same issue. My Vic Jr ports are closer to 1 3/8 x 1 3/8. I'm running Doug's Headers Tri-y made for the Falcon. Problem is that he ports are rectangular shaped ... approx 1 1/4 x 1 1/2 from 1 5/8 diam exit tube . The headers fit the Falcon perfect. I'm going to call some machine shops and see if they can reshape the header ports to square and weld in a square port replacement flange.
Kenny64 is offline   Reply With Quote
04-21-2008, 07:54 PM   #3 (permalink)
dragfalcon
try here, they have swap headers for the Mustang and Falcon for after market heads. 1 5/8 stepped up to 1 3/4.
Ford Powertrain Applications
67 with an attitude!
[img]http://www.fordmuscle.com/pictures/dragfalcon/FFW_2006_200x100x72.jpg[/img]
dragfalcon is offline   Reply With Quote
04-26-2008, 12:51 AM   #4 (permalink)
Kenny64
Ended up having a machine shop grind the sides of the header ports out at an angle to match the Felpro 1486 gasket (Edelbrock Vic Jr square ports). Came out pretty good, will definitely improve flow. Can't beat the fit of the Dougs Headers on the '64.
Intake manifold....match port to the heads question. RumpityRump All Ford Techboard 1 06-19-2005 10:27 PM
Port match giddyup1 All Ford Techboard 0 09-17-2004 08:04 PM
Should I port match my intake? mikemustang289 All Ford Techboard 2 05-03-2004 07:51 PM
New headers from Flatlander for raised port heads BOB PHILLIPS All Ford Techboard 4 12-05-2003 06:26 PM
port matching Air-gap intake to match VJ heads Cman All Ford Techboard 7 10-26-2002 11:47 PM
Probe Industries
