05-09-2008, 02:53 PM   #1 (permalink)
fredsmailes
gas gauge sending unit?
I've been trying to fix my gas gauge.
In searching I pulled the sending unit out of the tank
and found that there is fluid in the float,
it floats in water, what gives?
Is this normal, I can't find any leak and the
brass seens in good repair?
Its an original 64 Comet sending unit.
Fred
Don't let common sense and good judgement hold you back,
If your gonna do it do it !
fredsmailes is offline   Reply With Quote
05-09-2008, 04:24 PM   #2 (permalink)
round61
Re: gas gauge sending unit?
If you wipe dry the float you should be able to see the gas seeping through where the leak is. You may need to put a small hole in the float to drain the gas. Use a soldering iron and solder the hole up. Have a good look at the seam on the brass some times they leak there.
round61 is offline   Reply With Quote
05-10-2008, 09:35 AM   #3 (permalink)
69fury
the brass float in my 49 Willys Overland cost me about 9 buck at napa several years ago. Phone call to parts store?
69fury is offline   Reply With Quote
05-11-2008, 12:08 AM   #4 (permalink)
fredsmailes
Ya, I poked a hole in it and it was gas.
I took it apart and rersoldered it
floats even better now!
Fred
Fuel Sending unit or gauge ?? 72cj351 All Ford Techboard 1 08-13-2005 11:09 AM
Fuel Gauge Or Sending unit ?? 72cj351 Torino Pages 0 08-13-2005 08:39 AM
Fuel gauge sending unit Cokroach Falcon Pages 4 03-23-2005 01:13 AM
Pressure sending unit for VDO gauge? tim1859 All Ford Techboard 4 08-26-2004 08:12 PM
Fuel gauge and new sending unit? ntnbolt1 All Ford Techboard 0 05-27-2003 06:00 PM
