05-10-2008, 10:57 AM   #1 (permalink)
Stroker83
make a 9" fit my 65 Falc.
I read the tech post about narrowing a 9" but still had a question. Is there any reason you can't cut the existing weld where the axle tubes come into the pumpkin?
Stroker83 is offline   Reply With Quote
05-10-2008, 01:21 PM   #2 (permalink)
fredsmailes
Re: make a 9" fit my 65 Falc.
You can cut it apart anywhere you want, the problem is putting it back together so that everything thing is true. We always used an Alston
jig. It is basically a long straight steel rod with machined sleeves to fit in the centre and the axle ends so that everything is true when you tack it together. Sometimes the assembly came out so true that the rod would spin freely after the welding had cooled. Usually though it would pull one
way or the other just a hair.
Also we put braces on the back of a lot of them. So we would weld the brace on,let it cool then the axle ends.
Fred
Don't let common sense and good judgement hold you back,
If your gonna do it do it !
fredsmailes is offline   Reply With Quote
05-10-2008, 09:33 PM   #3 (permalink)
Stroker83
Thanks for the input.... I guess there is more than one way to skin a cat the hardest part is figuring out the way that makes it work right.
My boss said I could machine any parts I needed for the car... I guess it's good I work in a machine shop! Thanks again
05-10-2008, 10:47 PM   #4 (permalink)
fredsmailes
Perfect, you've got everything you need to
to make it right!!!
Fred
05-11-2008, 01:41 PM   #5 (permalink)
dpeeters
How much are you going to narrow the rear end and what will your final flange outside edge to outside edge measurement be? Assume you are not going to relocate the spring perches or??
I want to get a Curie made and I am just researching the measurements that people are using. If this has all been hashed out (many times probably) just send a link
Thanks, Dave
1965 Ranchero, T5, Stroked 351W
http://www.davepeetersphoto.com/imag...5_Ranchero.jpg
dpeeters is offline   Reply With Quote
05-11-2008, 03:14 PM   #6 (permalink)
Murff
If you haven't already seen it and used it, Currie has a great online calculator for determining your rear end, 9+ Rearend Calculator - Overall Width.
We built one a few years ago for a now gone project. Bought the pumpkin from Randy's Ring & Pinion for like $125, 3" DOM tubing and Torino style bearing ends from Art Morrison for another $125, then borrowed a friends alignment tool to set it all up with.
$250 and a couple hours and we had a rear end. Pretty cool.
Murff
"Deliverance" was NOT a documentary!
Murff is offline   Reply With Quote
05-11-2008, 04:25 PM   #7 (permalink)
Stroker83
I haden't see that link... Handy tool to keep the guessing monster at bay. I want to run the rear stock width, however I would still like to get an 8" tire (or more) I belive the stock width is
53 3/16???? Thanks for the link !!
05-11-2008, 07:49 PM   #8 (permalink)
69fury
handy link- i'll be needing 42-44 incher depending on....things
69fury is offline   Reply With Quote
05-12-2008, 03:18 PM   #9 (permalink)
Stroker83
"Things" I like that....
05-12-2008, 03:35 PM   #10 (permalink)
Murff
I hate it when my rear end is too wide because of...'things'.
Murff
Solid Lifter Valve Adjustment of a 390 FE "P" Code Engine JCAllison Galaxie Pages 44 03-30-2008 04:15 PM
1973 Ford Gran Torino Sport "Q" code jjj2007 Torino Pages 6 01-28-2008 07:19 PM
1977 LTD II, S-code ["SPORT II" clone project] $1200 MERCURYMUSCLE Vehicles for Sale 1 01-14-2008 04:28 PM
Disc swap prop valve, "T" fitting questions ? lgh1157 All Ford Techboard 3 01-01-2008 10:28 PM
"Victory by Design" on Speed, Ford Muscle series ga289stocker The Garage 0 07-08-2007 09:35 AM
