05-11-2008, 08:15 AM   #1 (permalink)
caddyking19
61 comet disc brake swap
hey i found this kit on ebay i was just wondering will this fit my 61 comet??? also im gonna out 65 mustang control arms on it will this all bolt up?? please help auctions almost over!!
caddyking19 is offline   Reply With Quote
05-11-2008, 08:16 AM   #2 (permalink)
caddyking19
Re: 61 comet disc brake swap
oh yea heres the link haha
eBay Motors: DELUXE RACING MODIFIED GRANADA HUB & PINTO SPINDLE KIT (item 290227665428 end time May-12-08 22:50:55 PDT)
05-11-2008, 09:20 AM   #3 (permalink)
Just Jim
Nope. The kit you posted uses Pinto spindles which won't work on a Falcon. With early Mustang upper and lower "A" arms this kit is what you need:
eBay Motors: GRANADA DISC SPINDLES / PARTS FOR COMET FALCON SWAP (item 140232082681 end time May-17-08 20:17:56 PDT)&
\'58 Morris Minor 289 S/S MM
05-11-2008, 10:04 AM   #4 (permalink)
caddyking19
ohh i see ok thanks im watching this in my ebay now..thats all i need for the disc brake swap right? except for a master cylinder
05-11-2008, 10:19 AM   #5 (permalink)
Just Jim
Some more parts will probably be needed. To connect the Comet steering to the spindles,V8 steering components will be required or tie rod sleeve adapters from Mustang Steve.Get a combo metering/prop valve off a Granada or disc braked equipped Maverick to complete the system. The master cylinder for a manual disc/drum Granada bolts right in.
05-14-2008, 10:44 AM   #6 (permalink)
3ondatree
The '61 upper & lower ball-joint studs are smaller than the later ones (at least they are on the Falcons). I had to machine some adapter sleeves for those too. It was either that or replace the control arms with ones that use the bigger ball joints (like the Mustang ones you mentioned).
Ryan
-'61 Falcon Futura 2-door, 200ci I-6, 17x8" Bullitt wheels
-'78 F-150 Ranger 2wd, 302ci V8, C4 trans
3ondatree is offline   Reply With Quote
disc brake swap 63boxtop Galaxie Pages 14 10-10-2005 07:27 PM
65 disc brake swap???? sleepysal Truck Forum 3 09-17-2005 05:55 PM
64 disc brake swap brake lines sleepysal Galaxie Pages 3 04-29-2004 07:22 PM
64 disc brake swap brake lines sleepysal Galaxie Pages 3 04-25-2004 01:37 AM
Disc brake swap 4u2nv All Ford Techboard 4 11-15-2003 12:50 PM
Probe Industries
