05-14-2008, 10:52 AM   #1 (permalink)
1965falcon1073
Trans ???ssss
Would a automatic out of a 1990 ford mustang 5.0 be a good trans for my car???, he says its a C4 but i think its an AOD???
Thanks for the help
1965 falcon complete restomod
1965falcon1073 is offline   Reply With Quote
05-14-2008, 01:45 PM   #2 (permalink)
1961gasser
Re: Trans ???ssss
I ran an AOD trans in my 61 with a 289 and worked just fine.
1961gasser is offline   Reply With Quote
05-14-2008, 08:23 PM   #3 (permalink)
3ondatree
Re: Trans ???ssss
If its out of what you say its out of, its definitely an AOD. As long as you aren't putting a huge amount of power and abuse on it, it's a great trans to use, especially for cruising or daily driver use. Make sure you run a good trans cooler too.
Ryan
-'61 Falcon Futura 2-door, 200ci I-6, 17x8" Bullitt wheels
-'78 F-150 Ranger 2wd, 302ci V8, C4 trans
3ondatree is offline   Reply With Quote
05-21-2008, 12:06 PM   #4 (permalink)
JBerryman
Re: Trans ???ssss
I'm running an AOD behind a stroked 5.0 with zero issues. Love it.
1963 Falcon Conv 5.0L, EFI, AOD, Mini Tub, MII, Big Discs
1963 Ranchero 5.8L, 5spd, Miny Tub, MII, 1 pc windows, Mini Tub, Big Discs
1968 Mustang under construction
JBerryman is offline   Reply With Quote
C-4 Trans dumping trans fluid Roarnracin All Ford Techboard 5 05-16-2007 05:58 AM
Trans brake , won\'t hold above 3500 rpm\'s , new trans ! HELP ! bad4rd C4 Transmissions 9 08-17-2006 05:21 PM
trans id 5wndwcpe All Ford Techboard 4 05-27-2005 11:20 PM
what is my trans ?? fordsemi Truck Forum 5 04-30-2004 01:31 PM
T-5Z trans oil help please RumpityRump All Ford Techboard 2 05-10-2003 08:26 PM
Holley
