05-15-2008, 02:53 PM   #1 (permalink)
Falcon Girl
Brake Booster & Master Cylinder
I have a 63 Falcon that I converted to front disc brakes . Now I need to know what will fit (brake booster & Master Cylinder) into my car . I don't want the Geo Metro set up if possible .
Falcon Girl is offline   Reply With Quote
05-15-2008, 03:45 PM   #2 (permalink)
Stroker83
Re: Brake Booster & Master Cylinder
How about the Prizim setup... Tottaly not the same!!
I have heard that the Ranger booster and m/c is a good setup
Stroker83 is offline   Reply With Quote
05-15-2008, 05:14 PM   #3 (permalink)
1bad6t
You really don't need power brakes on a little Falcon. Be sure to get Disc/Drum master cylinder. A lot of people go with a 67 Mustang master. I have a 89 Mustang master and use metric to SAE fittings on the brake line. Master Cylinder
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
05-15-2008, 08:35 PM   #4 (permalink)
3ondatree
I used a Mustang dual master cylinder (for a '69 disc/drum car) without power booster and it bolted right up. I had to remove the rubber bumper on the pedal so it could swing back a little further. It works awesome.
Ryan
-'61 Falcon Futura 2-door, 200ci I-6, 17x8" Bullitt wheels
-'78 F-150 Ranger 2wd, 302ci V8, C4 trans
3ondatree is offline   Reply With Quote
05-15-2008, 09:20 PM   #5 (permalink)
Falcon Girl
To be clear , 67-69 Ford Mustang power disc/drum master cyl. but w/o booster ? All the listings I see are for power disc drum systems .
05-16-2008, 03:03 PM   #6 (permalink)
Falcon Girl
Thanks guys ! I picked up a dual master cylinder w/o the booster today & it's in .
05-16-2008, 05:33 PM   #7 (permalink)
coosbaylumber
Usually, disk brakes up front require boosters, as they require more pressure at the pads to work. The rears are drum and fronts are disk.
There were some Mustangs done without booster brakes and disks up front but then required someone with a heavy foot to run too.
Wm.
Old Ford owner
05-16-2008, 05:56 PM   #8 (permalink)
3ondatree
Yes, usually, but a Falcon is surprisingly light compared to a '67-'69 Mustang or Cougar.
By the way, Falcon Girl, you should also get a proportioning valve to put in-line to the rear drums. I got a little black one with a knob on top on eBay for about $30. I put it on, adjusted it to 1/2 way open, and never had to adjust it again.
You probably know this, but run the rear drums off of the front reservoir, and front discs off of the back reservoir. The pressure switch goes on the brake line to the drums (just use a T right off the front reservoir).
Ryan
Brake Master Cylinder upgrade rsscoggins Galaxie Pages 6 07-09-2007 10:47 AM
Brake Master / Booster Question Galaxie_406 Galaxie Pages 4 03-14-2006 07:12 PM
change brake master cylinder on car that has been sitting for a while?? sharpshot71 All Ford Techboard 2 02-25-2006 07:14 AM
disc brake master cylinder problem fat64 Galaxie Pages 3 01-22-2004 06:26 AM
Rod between brake pedal and master cylinder jeffstar All Ford Techboard 3 06-11-2003 04:14 PM
Holley
