06-10-2008, 10:21 PM   #1 (permalink)
mjt8002
Question rear leaf spring relocation for 64 sprint HT
new to forum. just purchased my first falcon. Does anyone have any info on articles or companies that make a leaf spring relocation kit to run wider rear tires. I'm not having much success finding any info in previous threads. If so, does it adversly affect handling, gas tank, exhaust, etc...... Thanks in advance for any help
mjt8002 is offline   Reply With Quote
06-11-2008, 03:17 AM   #2 (permalink)
347falcon
Re: rear leaf spring relocation for 64 sprint HT
Try Crites restoration they will have what you need
Crites Restoration Products
Rick
347falcon is offline   Reply With Quote
06-14-2008, 06:01 PM   #3 (permalink)
dpeeters
You may have already seen these and I also recall reading about a narrow leaf spring that gives you some clearance but may not be as much as you are looking for
Ras sent me this note a while back:
[SIZE=3]I bought their rear leaf spring set up (B) complete with bushings. The springs were 225.00 and the bushing set was another 98.00. There springs ate nearly flat which reduces the roll factor and are only 1 3/4 wide as opposed to the stock springs which are 2 1/2 which allow an extra 3/4 per side clearance. http://www.eps-hane.com/RearLeafSprings.html They were great guys to deal with even sent me picture of their panhard set up.[/SIZE]
[SIZE=3]I'm running 17" rims with a 255/40 on the rear and did no tubbing, just a lot of measuring to get the right backset and offset. I have a 9" Versailles set up in the rear with disc brakes. [/SIZE]
Not sure how useful this thread is but there is mention of a fiberglass leaf spring that I believe is narrower?
http://www.fordmuscle.com/forums/fal...sc-brakes.html
Also another discussion on this topic,
http://www.fordmuscle.com/forums/all...narrowing.html
1965 Ranchero, T5, Stroked 351W
http://www.davepeetersphoto.com/imag...5_Ranchero.jpg
dpeeters is offline   Reply With Quote
06-17-2008, 07:28 PM   #4 (permalink)
mjt8002
Thanks for the info dpeeters. Got me pointed in the right direction!
06-18-2008, 01:09 PM   #5 (permalink)
dpeeters
I am also looking into the rear coilover kit from Rod & Custom http://www.rcmotorsports.net/RearCoiloverKit.html
Talked with Willie there and the locating bars are narrower than a leaf spring so you get another inch clearance, will probably give you all you need without re-working the inner wheel housing. Solves the "axle hop" problem too.
I have their MII front end and the components and engineering are excellent. The rear setup is great for the street, have not decided yet due to the $$ dave
Leaf Spring relocation? Lupins Fairlane Pages 2 01-03-2008 05:27 PM
leaf spring relocation Lupins All Ford Techboard 0 12-23-2007 01:14 PM
Crites Leaf Spring Relocation Kit 64RestoMod Falcon Pages 6 12-22-2005 01:43 PM
67 Stang Leaf Spring Relocation Nitmare67 All Ford Techboard 1 11-16-2004 09:51 AM
rear spring relocation deleted3 All Ford Techboard 2 05-28-2002 04:38 PM
