06-13-2008, 06:19 PM   #1 (permalink)
dziner55
66 Mercury Comet Caliente
I know this is a Falcon Forum, but I figure someone would have info on it's ugly half sister. A friend of mine is looking to put a disc brake set-up in a 1966 Mercury Comet Caliente. Is there a later model cheap swap?
I know the full size Galaxie in 1966 can use the 77-79 T-bird set-up with almost no modification.
Is there such a thing for the 66 Mercury Comet? The car is a 289,automatic if that makes a difference.
Thanks,
Vince
dziner55 is offline   Reply With Quote
06-14-2008, 12:18 AM   #2 (permalink)
postal
Re: 66 Mercury Comet Caliente
On my '68 Falcon I used a '69 Torino power brake setup. I would think that the '66 to '70 Falcon would be adaptable also.
I would thing that the '67 & up Mustang, Fairlane, or Torino systems should fit on the Comet.
TJ in GB
\"FLCN A\" BABY!
postal is offline   Reply With Quote
06-14-2008, 12:19 AM   #3 (permalink)
postal
TJ in GB
\"FLCN A\" BABY!
06-14-2008, 12:21 AM   #4 (permalink)
postal
On my '68 Falcon I used a '69 Torino power disc brake setup. I would think that the '66 to '70 Falcon would be adaptable also.
TJ in GB
\"FLCN A\" BABY!
06-15-2008, 08:35 AM   #5 (permalink)
colkerr
The trusty Granada setup will fit. I just converted my 64 Falcon and it worked great. As long as your upper ball joint has 4 mounting rivets it will accept the Granada spindle. You just have to reroute the front brake lines to a Granada front flex hose setup. Good luck.
colkerr is offline   Reply With Quote
06-15-2008, 08:38 AM   #6 (permalink)
colkerr
You will also need a different tie rod end which I sourced from Mustangs plus. A good parts counterman can also source these if you give him all the specs of the old tre.
06-15-2008, 10:03 PM   #7 (permalink)
dziner55
Thanks everyone, for the replies.
Vince
06-19-2008, 05:18 PM   #8 (permalink)
bk2life
Thanks,
Vince
are you talking front or rear discs?>
if front yes the mustang discs are a bolt on no brainer.
there are plenty of kit forms to do it also.
the rear is almost just as easy, they make bolt ons, and or a bracket that welds to the housing, and then everything bolts on
bk2life is offline   Reply With Quote
My 1964 Mercury Comet Caliente... SLCK64 Makin' Progress 5 06-03-2008 06:32 AM
64 comet caliente denh2000 Falcon Pages 8 04-12-2008 08:51 AM
1967 mercury Caliente VonMoldy The Garage 5 01-30-2006 07:45 PM
