06-14-2008, 12:07 AM   #1 (permalink)
geronimemo
fuel lines/brakelines
Igot a question what type of metal can i use for my gass lines and brake lines also what type of crimp is used single 45 double or buble? Also is it possible to use rubber fuel lines from the gas tank all the way to the pump ? this is for a 64 falcon
geronimemo is offline   Reply With Quote
06-14-2008, 12:23 AM   #2 (permalink)
83broncodude
Re: fuel lines/brakelines
I would use aluminum for the fuel line, as it is pretty cheap, and you won't have to worry about it rusting, buy a tubing bender and bend up a nice hardline where the stock on ran, to connect the rubber hose between the hardline make a bubble flare or just a single flare will work, no need to take the time on a double flare. on the brake line either steel or for a little more cash copper nickel alloy available at Napa and its alot easier to work with and will never rust, you will have to make 45 degree double flares to connect them to the brake fittings.
good luck
83 Bronco - 357W Extreme 4x4 cam and other stuff that makes it go.
83broncodude is offline   Reply With Quote
06-14-2008, 10:29 PM   #3 (permalink)
geronimemo
Thankyou
fuel lines johnny9927207 All Ford Techboard 2 11-22-2006 04:59 AM
brakelines glenntorinosport All Ford Techboard 0 09-03-2004 06:46 PM
EFI Fuel Lines dpfalls All Ford Techboard 1 03-09-2004 06:33 PM
fuel lines my1st65 All Ford Techboard 6 01-23-2003 01:10 AM
Should I get different fuel lines Otto All Ford Techboard 1 09-29-2002 07:22 PM
