06-22-2008, 08:50 AM   #1 (permalink)
64futura
dip stick
I noticed the tube my dipstick goes into is free floating. Where the tube meets the block it looks like the tapered end is out of the housing. I tried removing that piece the tube goes into, but no go. I removed the two front bolts and two on the bottom. Does this piece come of or is it part of the block? Not sure if there is another bolt I'm missing. Any help appreciated...it's a 260 by the by
64 futura, 66 ranchero, 69 vw fastback, 01 tacoma
64futura is offline   Reply With Quote
06-22-2008, 09:23 AM   #2 (permalink)
64futura
Re: dip stick
06-22-2008, 05:04 PM   #3 (permalink)
1bad6t
Re: dip stick
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
06-22-2008, 05:16 PM   #4 (permalink)
64futura
Re: dip stick
I wondered what one looked like that wasn't broken. Thanks...Anyone had to replace this tube? I guessing it's just pressed into the block?
06-22-2008, 05:33 PM   #5 (permalink)
ixtlan
Re: dip stick
Pressed into timing cover. Some have a O-Ring on the base of the tube. Most dont.
RatStang Restoration
Restoration, Paint, Body, Light Fabrication.
www.RatStangRestoration.com
06-23-2008, 03:14 PM   #6 (permalink)
64futura
Re: dip stick
Is this piece the same size as 289,302?
06-23-2008, 03:31 PM   #7 (permalink)
ixtlan
Re: dip stick
It is the same.
Unless you are trying to stay original I would make a flexible tube to replace it myself. The stick should be 20 1/4" long using the stock tube. If you make one the length would be dependent on your tube length. The important dimension is how far it extends into the pan.
is my stick too big ? hotrodconsolo All Ford Techboard 26 11-04-2006 03:29 PM
dip stick in oil pan 69fstbk All Ford Techboard 0 03-07-2005 01:30 PM
Oil Dip Stick cenos All Ford Techboard 2 01-15-2005 10:54 AM
460\'s with a stick? 67Comet All Ford Techboard 10 07-15-2004 11:04 PM
Oil Dip Stick bprigge All Ford Techboard 4 03-20-2002 07:41 AM
