07-04-2008, 11:12 PM   #1 (permalink)
64futura
idle
I read that the two bolt idler arm bracket it a direct fit for the stock three bolt one. On the two bolt the shaft is parallel with the bolt wholes where on the stock three bolt it is not. How bad does it affect the steering switching to the two bolt? My goal is to replace the bracket and use a roller idler arm. Will this change work with stock p/s? 64 falcon/260
64 futura, 66 ranchero, 69 vw fastback, 01 tacoma
64futura is offline   Reply With Quote
07-05-2008, 03:07 PM   #2 (permalink)
Iethiopian
Re: idle
The two bolt idler bracket bolts right on and does not affect steering in any way. I used the same set up with quick steer and bearings on my conversion.
Ras Daniel
Horus http://www.cardomain.com/ride/728238
Isis http://www.cardomain.com/ride/732653
Osirus http://www.cardomain.com/ride/816404
Does this car make my ass look fast?
Iethiopian is offline   Reply With Quote
07-06-2008, 09:54 AM   #3 (permalink)
64futura
Re: idle
Thanks for the info...What year/model will have the 7/8" shaft?
LOW IDLE damtheman69 Mustang Pages (1996-2004) 4 05-15-2007 03:13 AM
302 idle problems - starts but won't idle siscrew Late Model EFI Techboard 5 05-18-2005 10:30 AM
Cam Idle lakecityg All Ford Techboard 2 06-28-2003 01:36 AM
idle giddyup1 All Ford Techboard 1 04-12-2003 08:00 AM
idle giddyup1 All Ford Techboard 1 10-10-2002 08:00 AM
