07-20-2008, 03:04 PM   #1 (permalink)
njranch
electric system
What changes need to be made to convert my 63 Ranchero from a generator to an alternator?? Any good sources on the subject? Anyone done it recently?
njranch is offline   Reply With Quote
07-20-2008, 04:34 PM   #2 (permalink)
fredsmailes
Re: electric system
delete
fredsmailes is offline   Reply With Quote
07-21-2008, 07:21 AM   #3 (permalink)
1bad6t
Re: electric system
V8 or 6 cyl?? If V8 you will need the 3-piece alt mount,regulator for a alternator and change the wiring. If 6 cyl you will also need to swap to a later timing chain cover. The old style doesn't have the boss for the mounting bolts. For wiring diagram see http://1bad6t.com/images/gen2alt.jpg
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
07-21-2008, 10:23 AM   #4 (permalink)
njranch
Re: electric system
I'm replacing the original 170 with a 250 which is complete with the alternator aready mounted. I need to know how to connect it to my existing electrical system and what changes need to be made. Thanks
07-23-2008, 07:29 AM   #5 (permalink)
1bad6t
Re: electric system
The above link has the info to change the wiring. Have you checked for hood clearance yet using the 250?
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
07-23-2008, 12:42 PM   #6 (permalink)
Iethiopian
Re: electric system
Do a search there should be lots of pics and diagrams in the archives.
Ras Daniel
Horus http://www.cardomain.com/ride/728238
Isis http://www.cardomain.com/ride/732653
Osirus http://www.cardomain.com/ride/816404
Does this car make my ass look fast?
Iethiopian is offline   Reply With Quote
07-23-2008, 05:52 PM   #7 (permalink)
coosbaylumber
Re: electric system
Friend of mine and I did this about two years ago, using a 200 in his.
Biggest problem was in wires. We got a wire set out of a 65 or 66 Mustang, and it had the correct plug for going in to the alternator regulator, and the main loom at the firewall, but near everything else was missing. Chased the wires for the headlights, but seems to me there was a problem with the horn. I know we had to drill new holes for the regulator mounting.
Wm.
Old Ford owner
07-24-2008, 09:57 AM   #8 (permalink)
1bad6t
Re: electric system
Yeah, the generator cars got power for the horn relay at the regulator and the horn button grounded the horn for sound. The alternator cars got it from the fuse box and the horn button completed the circuit. You need to get power to the horn relay from the "A" terminal on the regulator (or battery). The alternator cars do not use a horn relay. You can buy the regulator plug at any parts store and make your own harness.
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
460 oil system Rangerwill All Ford Techboard 1 01-09-2008 12:27 AM
Is my fuel system adequate for a nitrous system? xrayengineer All Ford Techboard 4 03-28-2006 11:31 AM
What cold air system/filter system for 2001 Cobra? ricanchulo373 All Ford Techboard 2 07-12-2004 10:58 PM
N2o Mike and others regarding cooling electric vs. Flex does electric really free up hp?? KidPoboy All Ford Techboard 2 01-20-2004 06:21 PM
PCV system dave65FB All Ford Techboard 2 06-13-2002 06:08 PM
