04-14-2009, 04:47 PM   #21 (permalink)
falconguy52
Re: Widest wheels..."My plan for the sedan"
Hi 65falkone,
Just a real stupid question. What is the proper way (points) that one measures the width of a steel wheel. Is it from rim to rim, or from just inside point where the tire bead would sit? It has the Ford bolt pattern and has Ford markings (Company oval) on it.
I went to a Ford Only yard & I got plain steel rims that if measured from 'lip to lip' is 9". If measured from bead seat to seat it's about 8 1/2". I was looking for 15 x 8" steel wheels. Thanks
falconguy52 is offline   Reply With Quote
04-15-2009, 11:47 PM   #22 (permalink)
dpeeters
Lots of measurement information here, hope this helps
https://www.rsracing.com/tech-wheel.html
Dave
1965 Ranchero, T5, Stroked 351W
http://www.davepeetersphoto.com/imag...5_Ranchero.jpg
dpeeters is offline   Reply With Quote
04-16-2009, 04:07 AM   #23 (permalink)
FATNFAST
Thumbs up Re: Widest wheels..."My plan for the sedan"
Originally Posted by 1windsor View Post
You should do a write up and make it a 'Sticky' Mods, what say you?
I agree totally! could you make a tech exchange article out of this when your finished?
Rick in Indy "408 Clevor" 9.64@137 1.30 60ft
04-16-2009, 10:47 AM   #24 (permalink)
65falkone
I could condense the info into a bit more of a "step by step" guide with all relevant measurements.
Everything will be back together and car sitting on the ground this Saturday. I will post pics after including the all important "how does it look now from the rear shot".
As for the earlier question regarding how to measure a wheel I believe the actual width measurement is the inside of lip where the tire bead touches.
65falkone is offline   Reply With Quote
04-21-2009, 11:35 AM   #25 (permalink)
65falkone
So I tried to put it all together this weekend and..... I do need to run 1" wheel spacers. The frame to frame measurement in the tightest area is about 41.5" and the inside tire to tire clearance is 42" - just barely fits but I want more clearance. This will also bring the tire closer to the fender lip which will be fine.
As of right now the extreme outside measurement from tire to tire is 64". That is with 9.5" rims, 7" backspacing, Maverick 8" rear end and BFG G-Force 275 40 17 tires.
Ordering the wheel spacers today and should have pics up soon - will look pretty good.
Pierre
04-21-2009, 03:55 PM   #26 (permalink)
1windsor
Good luck with the fitment. Can't wait to see what it looks like all together!!!
1windsor is offline   Reply With Quote
05-01-2009, 02:52 PM   #27 (permalink)
65falkone
Re: Widest wheels...wheels on now!
wheels on and rear end in everything fits just fine with 5/16" spacers. Lots of space to fender lip, probably 1.25" and about 1" to the leafs. I need to get longer axle studs to be safe though. I will try and get the wheel tubs welded in this weekend and then this project will be done finally. Does not help that my hard drive crashed with all my pics on it.
Pierre
widest-wheels-my-plan-sedan-img_9729.jpg   widest-wheels-my-plan-sedan-img_9735.jpg
05-04-2009, 08:57 AM   #28 (permalink)
65falkone
After measuring again it looks like a 315 width tire would fit - just - with the right offset rim. This is without having to cut and notch the frame rail. I am considering going back to a 15" stock steel rim 10.5" wide and a more traditional looking tire profile (taller). That will be after I do the M2 front conversion though.
05-04-2009, 09:49 AM   #29 (permalink)
1windsor
Hey, that looks really good! Will you be able to lower it at all, though? Looks like it's sitting a bit high...well at least for my taste.
Still looks awesome, though!!!
05-04-2009, 10:26 AM   #30 (permalink)
65falkone
I agree it is way too high at present..... With the 275's in their current location I can lower it probably 4" to 5" without any tire clearance issues - except axle hitting frame problems possibly. I am going to wait until the M2 front suspension with dropped spindles is in to see how much to lower (don't want the backend being lower than the front).
18" wheels kimura97 Galaxie Pages 11 03-29-2009 08:23 AM
351c odd problem. Engine only starts when key goes back from "start" to "run" elvisjer All Ford Techboard 8 02-22-2009 04:38 PM
wheels for 5/8" studs bonfire All Ford Techboard 4 08-14-2008 05:35 PM
No "Avitars", or "Billboard Sigs"...? frankenford The Garage 5 07-01-2008 09:39 PM
Looking for four 15" wide steel wheels, 6 or 7" wide. ling102 Wanted 3 02-05-2008 06:38 PM
