06-23-2009, 10:27 AM   #1 (permalink)
lothair66
Question Trans Driven Gear
Hi Guys,
I need help on a trans driven gear question. I'm not sure which 4spd tranny is left hand drive and which is right hand drive. Is the BW T-10 left and the Top Loader right or vise-versa? My application is a 65 Comet Cyclone with a BW T-10, 289, 2.80's or 3.00's and 205/65/15's. any suggestions on the color code of the driven gear? The Tech guy at MAC'S was almost no help!
Thanks for any and all the help!!
Regards, Tom
lothair66 is offline   Reply With Quote
06-25-2009, 06:52 AM   #2 (permalink)
coosbaylumber
Re: Trans Driven Gear
Back about twenty years ago, had trouble with the big speedo gear inside my T10. Original was grooved and any replacement long gone. Used one of similar tooth count, same outside, but one that had hole in center too big. It was designed for yet some other tranny. I then had a friend make up an aluminum collar. We shrunk fit this into the gear and then onto the output shaft.
The replacement gear may be out there now, but this one has worked good ever since.
Wm.
Old Ford owner
Tranny Driven Gear lothair66 All Ford Techboard 1 11-08-2006 03:02 PM
Need T-5 Driven Gear Speedometer mikemustang289 All Ford Techboard 6 01-09-2006 01:11 PM
c4 driven gear Aussie65 C4 Transmissions 2 12-18-2005 04:14 PM
Changing driven gear in tailshaft for speedometer streetstang67 All Ford Techboard 6 09-23-2003 01:50 PM
What size trans cooler for 8\" convertor / street driven billy All Ford Techboard 4 06-16-2003 12:31 AM
