09-29-2009, 01:22 PM   #1 (permalink)
redbrand
c4 trans 1975 in a 1965-HELP
Have a 62 falcon with a 1965 289, c4 trans. Have a good 1975 c4 trans out of a 6 cylinder car and would like to know if will work on to my 65 289 engine. I know the bellhousings are different, but will my v8 bellhousing bolt to the 6 cylinder c4 trans and work. Any help would be great!!
redbrand is offline   Reply With Quote
09-30-2009, 07:40 AM   #2 (permalink)
dacofa
Re: c4 trans 1975 in a 1965-HELP
unless you're going to be easy of it, I won't do it. It should fit, but the clucth packs are weaker in the 6 cyl and won't last long up to the V-8. Unless $$$ is the issue, I'd look for a V-8 C-4.
Lead, Follow, or get the F%$K out of my way.
09-30-2009, 08:46 AM   #3 (permalink)
1bad6t
It according what size 6 cyl you're talking about. The 250 6 cyl and V8's used the same transmissions. The 6 cyl factory converter is a little bit looser than a factory V8 converter. The 200 C4's have less clutch packs. I know nothing about the BIG 6 cyl trans
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
b&M shift kit?? 1975 c4 1badasslx C4 Transmissions 2 12-18-2008 03:45 PM
1975 Wagon X-Factor001 Torino Pages 4 07-27-2008 04:33 PM
1975 Monarch 63Kcar All Ford Techboard 16 10-02-2005 08:22 PM
1965 GALAXIE C6 TRANS SWAP fgreene5732 Galaxie Pages 10 09-07-2005 08:31 AM
please help 1965 ford galaxie center console automatic trans shift linkage ergo Galaxie Pages 0 01-23-2005 06:08 AM
