09-30-2009, 08:23 PM   #1 (permalink)
tc1962
Rocker assembly torque
I have added an adjustable rocker assembly from a '64 144 to my '68 170. What do you think the torque should be for the assembly, about 30 lbs??
Thanks ahead of time....tc
tc1962 is offline   Reply With Quote
09-30-2009, 09:04 PM   #2 (permalink)
1bad6t
Re: Rocker assembly torque
30-35 ft lbs.
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
10-01-2009, 07:57 AM   #3 (permalink)
coosbaylumber
I used the torque values from the earlier installation. Which is a bit higher yet.
But before getting it tightened, bend back the arms, and measure the tip distances. If too great, it will clatter when using mush lifters. I had to obtain a set of longer pushrods. Then, make sure the torque to adjust each is about right, or they will loosen up on you.
Wm.
Old Ford owner
Rotating assembly hp & torque limit Sponge All Ford Techboard 9 03-15-2008 01:55 PM
TORQUE BOX FIRST or INNER ROCKER FIRST ? SCHOONER All Ford Techboard 6 08-12-2007 04:24 AM
Rocker Arm Stud Torque 351bolt All Ford Techboard 2 01-04-2007 02:16 AM
Sparkplugs and rocker arm torque 63fair All Ford Techboard 1 01-23-2003 10:40 PM
over torque rocker adjuster nut papadaddy All Ford Techboard 6 05-23-2002 08:52 PM
