10-03-2009, 09:54 AM   #1 (permalink)
papawfalcon
'62 RANCHERO drive shaft?
I have a "62 RANCHERO. This car came with a 3-spd.I now have a C-4. The problem is I have a larger drive shaft( not the small FALCON ).The drive shaft hit on the tunnel at the u-joint.I'm not sure if the motor and tranny is on the right angle.So the tail of the tranny will drop and the drive shaft will work.How do I check this I heard one way is the carborator needs to be level. Or the tranny tunnel is to small.I made the trans mount and it may be wrong.What drive shaft should be used? Thanks for any and alll help! Ken N.
FALCONS AND RANCHERO\'S FOREVER
papawfalcon is offline   Reply With Quote
10-03-2009, 12:52 PM   #2 (permalink)
Re: '62 RANCHERO drive shaft?
If the shaft is hitting it's HUGE, or the tranny mount needs changed.
The carb does not need to be exactly level. It will work at many angles.
I suggest that you mod your tranny mount to be 1 to 1.5 inches lower. If it does not clear then, you really need a different driveshaft.
FE
Honor!
10-04-2009, 06:38 PM   #3 (permalink)
papawfalcon
FEandGoingBroke,Thank you.I had to modify my mount.I was afraid the angle would be wrong! But NO! All I need to do now is get it welded and painted.Put my driveshaft togather.And install.Then on to wiring.Thanks again I've been all summer tyring to figure out my problem.I guess K.I.S.S. Ken N.
Drive shaft help! Cataclysm All Ford Techboard 1 06-06-2009 06:13 PM
Drive shaft nickgt350 Mustang Pages (1965-1973) 13 04-26-2008 08:30 PM
drive shaft help please mystikbrian Falcon Pages 8 11-28-2007 09:01 AM
C-4 drive shaft skooter C4 Transmissions 2 10-01-2007 05:15 PM
C4 Output Shaft - Slip Yoke - Drive Shaft - Pinion Yoke? ponyfool All Ford Techboard 2 09-18-2004 11:28 AM
