10-07-2009, 06:14 PM   #1 (permalink)
BIGKIDZ302
Talking 1964 ford falcon conversion
My Name Is Mike, I Have A 64 Ford Falcon Fantura. It Has A 170 Engine With A C4 In It. I've Switch All The Front End And Rear End Pieces All A Round For The V-8 Already. Yes This Car Has Disc Brakes All The Way Around It. I'm Putting In A 306 Ford Motor With A T-5 Transin It. I Need To Know Where To By The Clutch Padels And Clutch Cable For The T-5.not The Rod , The Cable For The T-5 Conversion. The Car Is An Auto. This Car Is All Original And Very Clean. Im In The Dearborn,mi Area, Would Like To Have Car Ready For The Detroit Auto-rama If Possible. Thanks For Any Help Possible.
BIGKIDZ302 is offline   Reply With Quote
10-07-2009, 07:18 PM   #2 (permalink)
retyler
Re: 1964 ford falcon conversion
Modern driveline if you don't mind the price. You may score on Ebay or give it a couple of days and maybe someone on here will have what you need. You will need the Falcon parts.
If you can fabricate, weld a small piece of plate to the clutch pedal and bolt on a later day Mustang quadrant and use the Mustang cable. That is what I did.
10-07-2009, 07:55 PM   #3 (permalink)
cartoad
Mike, Take a look at mustang steves site.mustangsteve.com If mustang stuff will work he has some conversion pieces that make it fairly simple, good parts and friendly on the phone.
cartoad is offline   Reply With Quote
10-09-2009, 05:22 PM   #4 (permalink)
BIGKIDZ302
Thanks Guys For All The Help. Im Checking Ou Everything.
10-14-2009, 03:45 PM   #5 (permalink)
falconguy52
Smile Re: 1964 ford falcon conversion
Have you considereed a hydraulic clutch? I used the Mcleod clutch set up which all the stuff is internal to the bellhousing. A line comes from the hydraulic clutch out the clutch square hole to what I did: I used a Ford Ranger slave cylinder and adapted the fitting comming from the line to mate with the Rangers clutch. It is small and can be bolted to the firewall and the slave rod can be connected to the existing clutch pedal with the pin that you can remove from the Ranger pedal. A plate can be slightly bent to copnform to the firewall & then you can mount the cylinder to it. The small resovouir is mounted next and above the master cylinder. Take a look at a Ranger truck set up and go from there. It worked for me. Probably about the same price or less for my setup was my expense.
falconguy52 is offline   Reply With Quote
10-14-2009, 05:52 PM   #6 (permalink)
decurion
Where in Dbn? I used to have a 65 falcon wagon that I put a t5 in. You may have seen the car around, the new owner lives in Westland. I used the Modern Driveline cable and crossmember, and they worked great. Just be careful which headers you use, they dont all work.
-Eric
65 Comet wagon, 60% of the time it works every time.
[<a href=http://i10.photobucket.com/albums/a142/1strealjeep/Comet%20pics/Cometfront-1.jpg] target=_blank>http://i10.photobucket.com/albums/a1...etfront-1.jpg]</a>
decurion is offline   Reply With Quote
10-16-2009, 05:49 PM   #7 (permalink)
BIGKIDZ302
Im At Outer Drive And Southfield. Taking All Advice And Parts That Are Avilable. Thanks Guys.
Front track width 1964 Ford Falcon Canuck All Ford Techboard 1 08-22-2009 08:42 AM
1964 Ford Falcon 64Pelican Falcon Pages 8 09-03-2005 06:24 PM
1964 Ford Falcon Squire Wagon aaronk The Garage 12 04-10-2005 06:53 PM
Ford Falcon Ranchero Pick up 1964 NoLongerHere2 The Garage 7 08-17-2004 01:28 AM
1960 ford falcon wagon disk conversion nathen Falcon Pages 4 06-28-2004 09:02 AM
