10-28-2009, 08:50 PM
65FalconLover
Is my '65 Falcon Futura over-weight?
I just had my car weighed today and was a little disappointed when I saw the scale reading. I've always beleived it weighed in around 2,625 lbs, plus a little more considering it was a V8 car. My old Ford reproduction pricing & specification guide says that's the weight for a 2 door hardtop Futura of my year, but doesn't specify details like engine size, etc. but I assumed it was close to that weight.
I also made some assumptions I was somewhat lighter than that due to past & recent changes to the car that should have put me well under that weight (aluminum heads, radiator, intake, carb, lightweight fuel cell, tube headers, etc) and several weight eliminating items like removing the entire heating & ventallation system (and no spare tire).
My rolling weight was 3050 lbs without me in the car. Is the scale I went to that far off or is the Ford spec sheet missing something? I have not even added a roll bar or other items. The only weight adding thing I've done was swap the 8 inch rear for a shortened 9 inch with larger tires & wheels out back.
I'm confused!
John
'65 Falcon Futura Pro Street w/347 stroker "The Hot Rod"
'04 F350 Lariat CrewCab dually PSD 4x4 "MOMS CREW"
'06 Acura TL "DADZ TL"
10-29-2009, 04:08 AM
347falcon
Re: Is my '65 Falcon Futura over-weight?
I think your scales are right on. I weighed my car and it is almost a twin to yours at the local grain elevator and it weighed 3000 LBs
Rick
10-29-2009, 07:25 AM
Just a couple fat dudes... Nothing to see here folks... nothing to see...
My 61 Moredoor is estimated #2700 and change full of fuel and my fat arse...
Honor!
10-29-2009, 08:15 AM
coosbaylumber
You may have saved 100 pounds in over all weight, but often base weights are on an empty fuel tank, no radio, base little engine with standard three speed tranny, cheap cloth seats. and other items to save a pound or two on weight. Sometimes the figures did not include oil or oil filter.
Those items alone ought to raise the overall weight 3-400 pounds.
Wm.
Old Ford owner
11-04-2009, 10:51 PM
L n L
I'll trade weights with you!
My '69 wagon (manual steering, manual brakes, lighter weight front disc conversion, LIGHT wheels, aluminum heads/intake/radiator) no speakers, no a/c, factory rubber flooring is a bit heavier than I had been led to expect.
Without me, it is right at 3600#!!!
About 300 more than I had expected. Oh well, I'm still hitting nearly 118mph at the finish line!
Lee
65 Factory Five Cobra, 302 efi, t-5, 12.5 @106
'03 Excursion 4x4, 6.0
'69 Falcon Station Wagon, 425W, 4R70W, 3.50, 11.51 @ 117.3, 3790# race weight
11-05-2009, 07:04 AM
frdnut
Lee
If you want to feel better about your wagons wieght just compare it to a new muclecar!......
As for the falcon wieght it sounds about right..
11-13-2009, 10:35 PM
1windsor
Sounds about right.
We need pics of your car!!!
11-14-2009, 06:44 AM
68sportcoup
you listed all you did to lower the weight.
but im sure you did things to rais the weight also.
v8 and trainy would add also the original tires and rims are realy light.
i would bet you got some big tires out back.
how about the rearend that 6cyl rear is alot lighter than a 9".
im sure thers more.
68 falcon sport coup 289 toploader 9\" 390\'s detroit locker
68 falcon undergoing v8 swap
67 falcon 351w auto
68 falcon fact ac
67 falcon next project no motor or trans no rot either
11-18-2009, 11:09 AM
#9 (permalink)
ROG30Y
Thats depressing,i was wanting to get mine to weigh 2800lbs with me in it.
1964 Falcon hardtop,terrible running 302 and t-5.should be a good project car....
