11-04-2009, 05:31 PM   #1 (permalink)
spg639
64 falcon front end
Hi can anyone tell me where I could find a new 65 manual V8 center link that is not to expensive, as I am doing the granada swap and want to replace the front end with new parts. I found the inner tie rod ends for the 65 at the local auto parts store for 25.00 and bought new 79 granada outers & sleeves, but no luck on the center link. Also do I use a 65 idler arm? Thanx
spg639 is offline   Reply With Quote
11-04-2009, 09:09 PM   #2 (permalink)
retyler
Re: 64 falcon front end
Try Falcon parts.com, or ebay, or one of the other Falcon vendors. Watch this forum for people selling parts.
What is cheap to you?
11-09-2009, 03:31 PM   #3 (permalink)
spg639
Thanks for the info I have been watching ebay and they are a bit pricey $300 to $460. I will give Falcon parts a try
11-09-2009, 08:13 PM   #4 (permalink)
retyler
Also check with NAPA or one of the other big auto parts stores.
11-09-2009, 08:40 PM   #5 (permalink)
65 BFX
AutoKrafters has all that stuff. They have a catalog that is a wealth of part #s and applications. Look em up on line and order a catalog, its free and Ive never had 1 problem with them. I ordered a full front end for a my cyclone and also for my 64 Sprint. Good quality as well and good customer service.
Alot of the 64 stuff interchanges with the 65 mustang. You may look up part numbers for a mustang centerlink and compare to the falcon link #. May be the same part for half the price.
1965 Cyclone B/FX clone, 347 sleeper 4 speed
1964 Falcon Sprint, 302 4 speed, sub .490 lift, 12.75ET, no NoS
real cars have 3 pedals ;-)
65 BFX is offline   Reply With Quote
11-10-2009, 12:21 PM   #6 (permalink)
retyler
Falcon is shorter than the Mustang. So it won't work.
11-10-2009, 09:51 PM   #7 (permalink)
65 BFX
Dont you mean narrower? What does length have to do with a center link.
11-11-2009, 01:15 AM   #8 (permalink)
1bad6t
If you stand them up side by side it will be shorter...if you lay them down it will be narrower. The holes for the tie rods are different too. See page 57 http://www.melvinsclassicfordparts.c...ages_53-59.pdf
The 64 V8 and 65 V8 stuff is different and nothing interchanges unless you have a very, very late 64 production number. To use a 65 centerlink you will need to change the steering column and steering box to get the right size sector for the pitman arm...or get a steering box from a 60-65 6 cylinder car
Jeff in Georgia
60 Tudor Falcon V8
64 Falcon Wagon V8
[SIGPIC][/SIGPIC]
11-13-2009, 12:08 PM   #9 (permalink)
rblante
Give these guys a try.
About Index - Rare Parts
I purchased my 64 falcon V8 center link from them.
rblante is offline   Reply With Quote
11-14-2009, 07:44 AM   #10 (permalink)
decurion
No need to swap out the column and box, just use a later pitman arm with the larger sector shaft. I have one and compared it to a 65 pitman arm and there was no difference other than the obvious sector shaft size. All 65 Mustang parts interchange, aside from the center link. I used a Mustang center link and cut it to size, but I wouldnt really recommend it because unless you get the measurments EXACT, itll give you a world of trouble (ask me how I know...). Falconparts.com and Auto Krafters are probably 2 of the best Falcon parts vendors Ive used, but Ill add Dennis Carpenter reproductions as well. Im not 100% on the idler arm, but Im pretty sure you should use the 65 idler. I have a replacement 65 arm that you may be able to use with your 64 shaft if youre interested.
-Eric
65 Comet wagon, 60% of the time it works every time.
[SIGPIC][[URL]http://i10.photobucket.com/albums/a142/1strealjeep/Comet%20pics/Cometfront-1.jpg][/URL][/SIGPIC]
decurion is offline   Reply With Quote
Front end help! Mustang ii into falcon. x00shocker00x Falcon Pages 2 09-10-2007 12:23 PM
64 falcon front suspension Jeffb All Ford Techboard 1 07-19-2004 08:22 PM
Falcon from da front deleted2 The Garage 1 02-20-2004 10:33 PM
Front end help for 62 Falcon Canuck Falcon Pages 2 08-30-2003 03:30 PM
Front end Help for 62 Falcon Canuck All Ford Techboard 2 08-06-2003 08:44 AM
