Go Back   FordMuscle.com Forums > General Forums > FM Video
03-05-2007, 10:26 PM   #1 (permalink)
DynoTom
521 BBF DYNO TEST 830 HP 701 TRQ
03-06-2007, 03:34 AM   #2 (permalink)
FATNFAST
WHOA!
03-06-2007, 09:45 AM   #3 (permalink)
DynoTom
She will make even more power than that.....I finally found a FMS A-460 intake ( quite a bit shorter and better for this size engine ) that will be going on it.....I also have to tune the carb in better as all of those pulls were running "slight lean to lean "......We will make some more dyno pulls after the changes are in.....I'm 99% certain we will break 850 FWHP this time out....
03-06-2007, 11:48 AM   #4 (permalink)
dfree383
Nice #'s !!
How much head work? What Valve Sizes are you using?
2007 New Years Resolution "Break into the 15's with a JA Cam"
[ This Message was edited by: dfree383 on 3/7/07 2:49am ]
03-06-2007, 12:15 PM   #5 (permalink)
DynoTom
These Trick Flow A460 big block Ford race cylinder heads are machined from A356-T6 aluminum and feature 340cc intakes, 172cc exhausts, 91cc chambers, bronze alloy valve guides, tungsten seats, big Chevy exhaust port openings and bolt pattern, and 1.760 in. spring pockets.
Assembled heads come with 2.30 in. intake valves, 1.88 in. exhaust valves, 1.640 in. dual valve springs for up to .850 in. lift, 10 degree titanium retainers, 10 degree machined locks, Viton® fluoroelastomer seals, ARP 7/16 in. rocker studs, and guideplates for 3/8 in. pushrods.
I used the heads "out of the box" no porting.....We did inspect them and flow test them though......
[ This Message was edited by: DynoTom on 3/7/07 3:16am ]
03-06-2007, 12:26 PM   #6 (permalink)
dfree383
What kind of flow did you see out of the box?
HTML code is On
Lakewood
