Go Back   FordMuscle.com Forums > General Forums > FM Video
06-22-2007, 11:37 PM   #1 (permalink)
admin
1969 Mach 1 Restoration - Slide Show
This three-part series was on YouTube. It's entertaining, though the music gets annoying.
Part 1:
Part 2:
Part 3:
admin is offline   Reply With Quote
06-26-2007, 07:43 AM   #2 (permalink)
Mikes66
Re: 1969 Mach 1 Restoration - Slide Show
Questions:
What was that coat they put on of dark red, before the final three coats were appllied?
How long between coats, or just started again after once around?
How long to wait for clear coat application?
What happens if you wait a day before clear coat?
I have painted cars in the back yard before, but that was 25 years ago.
I never did more then 2 coats, and never used clear coat. I will be painting my 66 in the back yard, I can not afford the $5000.00 everyone in my neighborhood wants to charge me. I figure for $800.00 in paint and materials, I will get a very good paintjob.
[SIGPIC][/SIGPIC]
06-29-2007, 02:58 PM   #3 (permalink)
stang69
ive heard wait till basecoat gets tacky around 30 minutes between coats and same for clearcoat.. i think it must be cleared after basecoat?
stang69 is offline   Reply With Quote
07-19-2007, 09:46 PM   #4 (permalink)
stang69
hey i seen this same car on ebay a few months ago for sell... the owner had a myspace account with about 80 pictures of it.... does anyone know the site??? really like the color viper red.. was wanting to get better look at car.....
07-20-2007, 12:08 AM   #5 (permalink)
Base coat to clear coat is 20 minutes minimum (depending on humidity and temp and reducer) to a couple hours if necessary. I've known people to wait a whole day to clear but they wet sanded the base first (I don't recommend waiting a whole day, you will get a much poorer adhesion to the basecoat in my opinion)
I didn't watch the video's becasue the 69 is NOT a body style I care to look at... Sorry...
FE
07-21-2007, 12:31 PM   #6 (permalink)
65ROCKETMAN
If your painting outside, the odds will be against you most of the way. Some do's and do not's. Keep the car out of the sun, the metal needs to be at a normal temp. Don't paint under a tree. Us lots of water on the ground and surrounding areas. Paint early in the morning when there's less wind and daily heat. Check the weather. Use correct reducer for your temp. expected. Let each coat tack longer than required. If major flaw becomes a issue, STOP and stop wasting the paint and money. Find a paint shop and try to rent their booth on a weekend. Let the mess made dry good and reprep the car for a reshoot. All the above varies with the type of paint being used and your talents. Good Luck
In progress '65 Mustang F/B, Another '65 F/B coming for resale, Finishing a '68 F/B Bullet car.
65ROCKETMAN is offline   Reply With Quote
HTML code is On
CE slide a links? BLACK65FORDFALCON All Ford Techboard 3 07-15-2005 01:40 AM
Slide on in PhatFalcon The Garage 8 05-28-2003 08:43 AM
1969 Mustang Mach 4 ! Runs 4 351 Ws for over 1400 cubes! Old School Cool! DynoTom The Garage 2 10-12-2002 11:09 AM
1969 Mach 1 project BobCat All Ford Techboard 10 06-30-2002 02:21 PM
1969 Mach 1 weight MightyMach All Ford Techboard 3 03-16-2002 10:39 PM
