Go Back   FordMuscle.com Forums > General Forums > FM Video
11-02-2007, 07:12 PM   #11 (permalink)
Iethiopian
Re: Why We Drive Fords Instead of Chryslers
I just got in and I swear I have only had one beer. That is the funniest s@it I have seen in awhile. What the hell is he talking about, is that a part for the mars rover or the Lunar module probe? That goes in a car? Hummm. What country is this from and are they even speaking english?
Ras Daniel
Horus http://www.cardomain.com/ride/728238
Isis http://www.cardomain.com/ride/732653
Osirus http://www.cardomain.com/ride/816404
Does this car make my ass look fast?
Iethiopian is offline   Reply With Quote
11-04-2007, 06:20 AM   #12 (permalink)
jrosengarth
I'm laughing so hard it could put me in the hospital... Thanks Murff, I needed that!
-J
http://www.concentricsoft.com/Personal/Jim/Truck/TruckRebuild420(sig).jpg
F150 Rebuild Project Website
jrosengarth is offline   Reply With Quote
11-04-2007, 05:37 PM   #13 (permalink)
67falconer
I bet if you play it backwards I has satanic messages and stuff in it.
Thread Killer
67falconer is offline   Reply With Quote
11-06-2007, 04:00 PM   #14 (permalink)
blkfrd
I love the part about the "...diagnostics manual and songbook"
Tracy Blackford: Anaheim Hills, Ca
11-10-2007, 12:38 AM   #15 (permalink)
xcgxl
It's a JOKE isn't it?
This guy was serious ABOUT HIS "ENERGY POLARISER"
peter brock energy polarizer - calaisturbo.com.au
An Energy Polarizer transmits a high energy mainly generated by the vehicle to which it is attached.
This high energy field - A.B.A. Energy - causes all molecules in it's sphere of influence to be aligned or polarized to the direction of the high energy transmission, and are held in a linked or aligned state.
These molecules are subject to a vibratory rate dictated by the Polarizer.
The printed circuitry in a Polarizer causes a multiplicity of frequencies to be transmitted, affecting each molecule and allowing that molecules and it's environment to absorb specific vibration levels including noises, vibrations resonance and impact harshness which are always present in any vehicle and also to dampen out the effects of imperfect manufacture of vehicle components.
The overall effect on a motor car is to absorb road shocks more completely and quietly, to reduce overall vehicle noises - both inside and outside - to achieve greater efficiency of the power train and steering systems, improving the engine and suspension performance and to create a more pleasant environment for the driver and passenger.
Certain frequencies have not been "tuned out" as they are necessary for increased road safety.
The energy transmitted from the "Energy Polarizer" always flows to that area most effected. That means a major problem area still remains a problem, and the energy is effectively wasted on that area since the overall vehicle is deprived and consequently is less enhanced. So a correctly manufactured and maintained vehicle will always be superior to one that is not, but all vehicles benefit from the fitment of an Energy Polarizer.
It should be noted a vehicle which normal requires high octane leaded fuel is then able to operate on low octane (92) unleaded fuel, without any ill effects whatsoever, when an Energy Polarizer is fitted.
Tyre pressures must be lowered to maximise the effect of an Energy Polarizer. Recommended tyre pressure:-
Standard and 60 series tyres - 24 P.S.I (165 k.P.a).
45 / 50 / 55 series tyres - 22 P.S.I. (150 k.P.a).
Light trucks and commercial vehicles - 30 P.S.I. (210 k.P.a.)
xcgxl is offline   Reply With Quote
HTML code is On
fun with fords IAPEXL8R FM Video 3 09-27-2007 09:05 PM
Fords Today - Fords Tomorrow - Fords Forever Calspec The Garage 14 07-22-2007 12:23 PM
Replacing Oil drive with billet drive 73FOMO All Ford Techboard 5 11-16-2006 06:16 PM
Other 9\" Fords cjjtulsa All Ford Techboard 1 09-12-2006 08:11 AM
Gear Drive vs Chain Drive..... Pros and Cons mlanden All Ford Techboard 22 05-02-2005 08:37 PM
