Go Back   FordMuscle.com Forums > General Forums > FM Video
02-08-2008, 01:13 PM   #1 (permalink)
strtcar
Vortech Supercharger
1967 Mustang, 302, s-trim. Second time firing it up, need to do some more fab work in intake tube/hat, etc.
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
[URL="http://chicago-classic-mustangs.com/"]http://chicago-classic-mustangs.com[/URL]
02-08-2008, 01:32 PM   #2 (permalink)
72BlackOnBlack
Re: Vortech Supercharger
Nice. How many pounds of boost are you gonna run? What are your projected #'s?
72BlackOnBlack is offline   Reply With Quote
02-08-2008, 01:36 PM   #3 (permalink)
strtcar
its running 9:1, hypo pistons so ill keep it under 10lbs. I'd like to get 450 to the rear if I can. Maybe some meth injection later down the line.
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
02-09-2008, 10:47 AM   #4 (permalink)
mrtbolt64
Being only 10lbs of boost on a blow thru you most likley not need the meth as the fuel added threw the carb cools down the intake charge.
Nice project
1992 mustang lx coupe, caged, mini tubbed, 393 with Novi2k supercharger 11lbs of boost, BS3 EFI on 93 octane. 9.59 @143
1997 F350 psd 4x4 http://media.putfile.com/Mustang-Novi2k
mrtbolt64 is offline   Reply With Quote
02-10-2008, 11:17 PM   #5 (permalink)
trukstopcowboy
NICE!!! bet you cant wait to drive her. how much did that cost you? do they make one for the old v belts?
66 FAIRLANE 500 2dr.
trukstopcowboy is offline   Reply With Quote
02-11-2008, 06:37 AM   #6 (permalink)
strtcar
I dont want to know how much its going to cost in the end. Figure the Kit, an $800 carb, upgraded fuel system, new ignition, etc.
The vortech kit is from a 90GT mustang. So im running serp belt, reverese water pump, new radiator, etc. So basically i've got a late model 5.0 front drive in a 67 mustang. Paxton (basically same as vortech) has a "bolt-in" kit for v belts.
[SIGPIC][/SIGPIC]
1967 Mustang Coupe
02-15-2008, 06:56 PM   #7 (permalink)
sharpshot71
meh, i would run it as is. should be fine
HTML code is On
vortech t trim blown33 All Ford Techboard 4 08-28-2007 12:29 PM
Saleen or Vortech 5.0 intake manifold, where can I buy new? 67fastback Late Model EFI Techboard 2 12-02-2006 09:12 AM
V-2 Vortech Supercharged 32 Valve 5.4 in 02 \'Stang thecarphotoguy1 The Garage 0 04-04-2005 09:35 PM
2001 cobra with vortech ant123 All Ford Techboard 2 02-08-2004 02:39 PM
BOSSLX 10.50 86 Stang! Vortech Blown 306! DynoTom Late Model EFI Techboard 0 04-20-2003 06:51 PM
