It has it's original 390 FE engine which has been built up to 425 HP. It is a factory 4 speed car with top loader transmission. I have the Marti Report. It is 1 of 753 with this engine/transimission combination. Original color is Clearwater Aqua and car needs a repaint. Car is very straight with solid rear quarters, rocker panels, trunk pan and bottom of doors. The car had a vinyl roof and there are some rust issues near the back window on the sail panels that will need repair. It has black bucket seat interior which is original and in great shape for a car 40 years old. A couple of small tears in the upper portion of the drivers seat and on the door panels. Carpet and headliner need replacing. Dash has some cracks. This car runs and drives excellent with tremendous power. The engine dyno-ed at 425 HP and 451 ft pounds torque. I have receipts for over $12,000 in engine and mechanical work. The engine was professionally built by American Racing balanced and blue-printed with the best in performance parts.
Parts include:
Edelbrock 6005/06 Performer Aluminum Heads
Edelbrock 7105 Performer RPM Aluminum Intake
Holley Double Pumper 4 barrel Carburetor
Holley 12-832 High Output Heavy Duty Mechanical Fuel Pump
JE Forged Pistons
K&R Rods
Competition Cams 1046 Aluminum Roller Rocker Arms
Edelbrock 7106 Performer Cam – Duration 296/296 325/325 Lift
MSD 8594 Pro-Billet Distributor
MSD 6420 High Performance Ignition System w/Rev Control and Blaster 2 Coil
Ram Clutch 1519 184-Tooth Billet Flywheel
Ram Clutch 306 11” Disc 300 Series
Ram Clutch 437 Pressure Plate
Hooker 6130 Super Competition Headers with Dynomax Ultra Flow Mufflers through 3" Stainless pipes
Milodin 31130 7 qt. Deep Front Sump Oil Pan
Front Sway Bar
New Ball Joints
New Lower Control Arm Bushings, Strut Rod bushings and Upper Link Bushings
New Shocks Front and Back
New Coil Springs
Tilton Standard Duty Super Mini Starter
Lakewood Safety Bellhousing.
