I used the 1979 Thunderbird disc brakes for this conversion. On a 1967 Galaxie the spindles used the same ball joints as the drum spindles did. The outer tie rod end u can make work from the drum brake installation. You just have to enlarge the hole a slight bit for the cotter pin. I got remanufactured calipers on it now and a remanufactured master cylinder for the 79 Thunderbird. I replaced my brake lines. And got the perportioning valve off the 79 Tbird.
<font size=-1>[ This Message was edited by: 1967xlfastbackgalaxie on 11/7/03 1:07pm ]</font>
