disc brake master cylinder problem
Okay, so you used '71 Galaxie front calipers, spindles, and rotors. So far so good.
And you had a stock single-circuit fruit-jar POWER master cylinder/booster assembly on the car, and everything worked well. Do you know what the bore of that master cylinder is?
Next, you changed to a '71 POWER master cylinder on the '64 booster. Do you know the bore of that master cylinder?
A few things come to mind:
a) Trapped air is one.
b) A change in hydraulic ratios because the new master cylinder bore is larger than the old one. Is the pedal travel noticeably shorter now?
c) Incorrectly adjusted pushrod not allowing sufficient master cylinder travel.
d) Screwed-up combination valve (okay, it's unlikely but if nothing else...)
<font size=-1>[ This Message was edited by: JEM on 1/22/04 5:40am ]</font>
