04-24-2004, 11:38 AM   #1 (permalink)
sleepysal
64 disc brake swap brake lines
Newbee here. Great site! I am ready to do my disc brake swap . I have T bird spindles ( disc ,calipers out tie rod end
bearings,seals , and prop.valve) Master cyl. front brake hose,and fitings.
My question is: What if any tips do you have on laying (routing)bending the hard lines?What worked best for you ? what should I avoid, or be aware of? Any input from you GURUS would be great Thanks SleepySal
04-24-2004, 03:01 PM   #2 (permalink)
deleted3
I'd recommend using coat hangers to sample route the lines first. That way you'll be able to see what kind of obstacles, etc you have to deal with.
04-24-2004, 08:37 PM   #3 (permalink)
cpike
You'll probably have to move the brake hoses and brackets forward on the frame similar to the t-bird, unless you can find some hardware to change the direction of the brake hose out of the caliper.
If you have not done brake lines before, you'll need a tool to bend and a tool to cut the brake lines, and also a flaring tool, and some brake line. I got these from Summit, but they are easily found elsewhere.
The coat hanger idea is especially useful. It is amazingly easy to bend a brake line the exact opposite way you intend to. You'll also have to bench bleed the master cylinder...
cpike is offline   Reply With Quote
04-25-2004, 01:37 AM   #4 (permalink)
sleepysal
great help I will use the coat hanger tip [img]/phpBB/images/smiles/icon_bow.gif[/img] I 'll let you know how it goes. I have a few projects on my to do list;disc brake swap, head light realy, lokar throttle and kick down cable,altswap and maybe an air bag set up. Whwn shw's done or 1/2 way done I'll post some pics.
FX Comet outstanding ride by the way Major props sir.
Lakewood
Probe Industries
