05-18-2004, 01:58 AM   #1 (permalink)
Stroked
Convert 260/3spd to 390/c6????
Well the tranny in my '63 started acting up and I have to either fix it or swap it out. I have a 390/C6 out of a '74 F100 2wd pickup and was wondering if I could put it in my car. Its a 1963 Galaxie with a 260 V8/3-spd with overdrive. Am I crazy? I don't know if a pickup tranny is any different from a car tranny or not. I know that a c6 wasnt available in '63 but I could do a little fabricating if neccesary.
Thanks,
Jared
<font size=-1>[ This Message was edited by: Stroked on 5/18/04 1:00pm ]</font>
Stroked is offline   Reply With Quote
05-18-2004, 02:37 AM   #2 (permalink)
65Fourspeed
Thats not crazy at all...that won't be too hard a swap..63 Galaxies came with 390's..as far as the C6 you might need to modify your drive shaft and make a crossmember for the tranny mount.,,Hey If I can stick a 1953 Cadillac and a 41 La Salle tranny in a 1960 GMC..You can certainly do this ..[img]/phpBB/images/smiles/icon_tup.gif[/img]
65Fourspeed is offline   Reply With Quote
05-18-2004, 02:47 PM   #3 (permalink)
Stroked
Thanks for the reply! I figured it wasn't too crazy. I'll have to go out and do a little measuring to see how it compares.
Jared
05-18-2004, 03:45 PM   #4 (permalink)
Stroked
Hmmm....I guess I would have to get a front sump oil pan, which wouldn't be too big of a problem.
Jared
05-18-2004, 05:28 PM   #5 (permalink)
65Fourspeed
Cool....Its amazing that Ford used a little engine like that in those big cars...A 6 banger is even worse!!!
05-19-2004, 09:35 AM   #6 (permalink)
jakengle
Jared,
You'll need a front sump pan, frame-to-engine brackets from a 352 or 390 car, engine mounts, modified/fabbed trans crossmember, ex manifolds/headers for the car, new exhaust, big block radiator, heavier front springs and various linkage plumbing parts, etc. I think the rear end in small block cars was not a 9", but if you're not racing it you may be OK. You'll have to have a drive shaft fabbed/modified.
All of the stuff accept the C6 mount should be off the shelf or junkyard/ebay.
jake
<font size=-1>[ This Message was edited by: jakengle on 5/19/04 8:38pm ]</font>
jakengle is offline   Reply With Quote
05-19-2004, 02:54 PM   #7 (permalink)
Stroked
Thanks for that rundown of parts that I'll need! Thats pretty much what I had figured I would need. I'm almost positive my car has a 9 inch rearend.
But, I have no earthly idea where I'm going to get a driveshaft built/modified at. I live in the middle of nowhere with no custom shops even remotely close. Unless the machine shop could do it, but thats not likely.
Jared
05-19-2004, 03:17 PM   #8 (permalink)
tbirdchick
Yep, you have a 9" small bearing rear end. Since your '63 had a small block, your ring gear, depending on ratio might be an 8 3/4". But any 9" center sections will fit the housing if you decide to change rear gears.
As to shortening a driveshaft, if your local machine shop has a welder, they can do it for you. You can even do it yourself if you or a friend can weld. Here's a link explaining how:
http://www.galaxieclub.com/tech.html
Jan
tbirdchick is offline   Reply With Quote
Powerhouse products
